Question about Compaq Presario 900US Notebook
Compaq Presario 900 power cord connection problem
I recently started noticing that my laptop's power cord was not making good contact with the notebook. I had to adjust the connecting piece is strange ways make contact so the computer would stay on. Then no contact could be made at all. I think this may be a problem with the connection inside the laptop itself. I tried taking the screws out of the bottom of the computer to disassemble it. However, I could not take the bottom off entirely. It seems there is something preventing it from opening all the way. Anyone have knowledge of how this thing comes apart?
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
I've fixed a couple and finally resorted to using a cable retention device like the one in this video to stop the constant tugging and jerking that seems to cause the failures. PS the design of the pins/sockets is really shabby.
Posted on Mar 04, 2008
If you do a Google search on your PC with the word "disassemble" or "repair instructions" you will likely get a hit. After you carefully get the motherboard out, the problem is typically bad solder joints on the dc port to motherboard. Make sure to use the least heat (that is, lowest wattage soldering iron) possible to remelt the solder. There are a few sites you can Google for "dc power port repair." If you are unable to do this many small firms advertise the service. Good luck
Posted on Jul 28, 2007
  • 624 Answers
As Pastorm stated it could be the socket, however, it could also be damage to the power plug that plugs into the laptop. My experience has been that I?ve had to replace far more damaged jacks by far then sockets. Usually what happens is that someone trips over the power cord and puts strain on the cable where it attaches to the jack. A quick test is to plug the DC jack into the laptop and while holding the jack still wiggle the cable where it attaches to the jack. If that doesn?t do it try holding the jack and wiggling it in the laptop socket. One or the other should cause a break in the power and you?ll know what to get fixed or replace.
  • 98 Answers
It seems like the power jack on the laptop has to be resoldered to the motherboard. More than likely you will have to take the whole laptop apart to reach the bottom part of the motherboard and do de soldering work.
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I use a Compaq CQ60 laptop. Recently I noticed that when I plug in the power cable the charging indicator at the point won't come on. Yet touching the Earphone slot with the back of my hand indicated that...
Hello.
If you are not getting total power, the most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 30, 2010 | Compaq Presario CQ60-220US PC Laptop
Need ac adapter/power cord
You can get a replacement power cord for this laptop from any elctronic or computer store near you like Besbuy or Radioshack, of you can order it online from this sites.
http://www.nextag.com/compaq-presario-700-power-cord/products-html
http://www.bizrate.com/laptop-accessories/compaq-presario-700/
Apr 29, 2010 | Compaq Presario 700 470024-192 Notebook
My compaq presario 2100 will not start up the power cord plugs in and when you wiggle it it somtimes would work but now wont at all. thank
1. You possibly have a damage ac cord
or you have damaged connecting plug at the PC .
2. try to obtain a new AC cord.
3. Another possibility is the power supply for the PC needs replacement.
4. A PC technician can determine this for you.
Contact Compaq for repair rates because most likely this is a special power supplied system.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario c700 WAS WORKING I SHUT IT DOWN AND NOW IT WILL NOT POWER ON at all
Is the power cord/brick *firmly* plugged in in all places? Sometimes, the cord from the brick comes out slightly, breaking the power connection. If your battery is old/no longer holding a charge, the machine wouldn't start again. Also, if above is ok, remove the battery, plug the power back in. Does machine start now? If it does - replace battery.
gurutim
Mar 09, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Compaq presario M2000 power cord won't charge my laptop
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
Jul 15, 2008 | Compaq Presario M2000 Notebook
Compaq Presario 900 Series PP2140 Power Up
I think you sould check your batteru first.
  • Remove your battery from lap.
  • Add power card to lap.
  • Make on without battery.
  • If it works, then you need to replace the battery or you can chek your lap with another battery, if it fixe your problem. Then you should replace the battery.
Thanks and Good Luck
Iqbal
May 03, 2008 | Computers & Internet
Compaq Presario 900
copy the softwares in safe mode.
for this
power on ur laptop
then press F8 untill u see a black and white screen
now select safe mode and then copy the dvd
Feb 17, 2008 | Compaq Presario 900US Notebook
Compaq Presario 900US Notebook Logo
286 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
