Question about AT&T Motorola RAZR2 V9 Cell Phone - Purple
Motorola RAZR2 V9 new phone wont charge
Just brought the new V9 when I plug the charger in the light goes on green to say charging then the phone automatically turns on and stops charging and says battery low and wont continue to charge???
  • 4 more comments
  • Courtney March Feb 16, 2009
    i plug the phone in to charge the light goes on to say is charging then the phone automatically turns on then it goes to battery low and wont continue to charge.
    i plug the phone in to charge and the lights go on he say its chargeing then it automaticaly turns and and says battery low then wont continue to charge
  • Anonymous Feb 27, 2009
    exact same problem
  • Anonymous Mar 16, 2009
    to charge
  • Anonymous Apr 13, 2009
    Same problem as the others - any solutions out there? Its frustrating and you just know the service provider is going to tell you to contact motorola. Has anyone else tried contacting mortorola - after you finally negotate their website they're no help either. I think we've been sold a dud.
  • Anonymous Mar 28, 2014
    I was charging my phone and I believe the charger shorted out either my phone or the battery
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Posted on Apr 25, 2009
  • 3 Answers
Use data cable and charge from USB of your computer. It works!!!
Posted on Jun 12, 2009
My motorola motor razr2 when i put charger in it starts to charge and phone turns on and green charge light goes out and it stops charging
ok this can be numerous things lets start with slide the charger cable out gently see if at any time it starts charging as you do this. No 2 could be the battery getting week, and loosing a cell in it. No.3 this is a software glitch that the phone needs for the software to be reinstalled which will take a technician familiar with modding and software.
Jun 19, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
My phone wont take a charge on my car charger or my house charger, this happened suddenly, help
might be the battery or charging port....u can go to carrier store and test a battery there, if not battery its charging port...call them and ask for replacement
Mar 22, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Charging Problem once i plug my phone to the charger it shows th green light but immediately my phone would come on and then the green light goes off and the phone stops charging
I had the same problem with my Razr V9,... and Motorola and AT&T were of no help!... They both claimed that it was a result of physical damage to the charge connector!... I find this hard to believe, since I used a USB connector to charge my phone via my computer, and that seemed to cure my charging woes!... I've been charging my phone in this fashion since then, and it seems to have no problem, thus far!... How can Motorola and AT&T make a claim that it's due to physical damage to the charge connector?... If that were the case, wouldn't one have the same end result by trying to charge it via a USB connection???... It's still a physical connection!!!... Hope this helps!
Mar 07, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola V9 will not charge
try to clean the surface connection on the phone using very little screwdriver
Aug 22, 2009 | Apple iPhone Smartphone
Razr v9 won't charge
well take it back to where you purchased it from..
Aug 01, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
My brand new motorola razr v9 would not charge, the moment you remove the charger the phone goes dead. And when charger is plugged- in the following message appears ''battery low cannot program''. Thank...
If it is a brand new phone, it will not cause this problem. You should return it or exchange it for a better phone ( if you still have the warranty card). The problem here is your phone's battery. Your phone's battery is not functioning well either it's old or corrupted. The solution is to change your battery.
Jul 27, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Open Questions:
See all AT&T Motorola RAZR2 V9 Cell Phone - Purple Questions
AT&T Motorola RAZR2 V9 Cell Phone - Purple Logo
2,333 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
