Question about Samsung RS2534 Side by Side Refrigerator
Leak on freezer side door from control panel samsung RS2534
I have a small continuous leak from the control panel on the freezer side door. There are no other leaks. Question, how do I get the panel off? Does it pry off or what?
  • 183 Answers
The trim unclips, to remove gently prise off using a small knife, you may find the you have either a faulty water inlet valve or the ice flap is not closing correctly. Regards Advisor
Posted on Aug 21, 2007
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
The unit won't stay on.
If the refrigerator wont stay on the start relay may be defective. This may have been caused by the leaking door that overloaded the system. The relay is a small box mounted to the side of the compressor and provides power to the compressor start winding for a split second at start-up to help get the compressor get started. If its defective the compressor may run off and on (a lot) or not at all and the refrigerator will not get cold enough. Fairly easy to do and reasonable
May 17, 2014 | Samsung RS2534 Side by Side Refrigerator
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
Flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Mar 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Fresh food side warm. Freezer works fine.
I think you are short of refrigerant, needs to be topped up and checked for leaks.
Mar 03, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534WW
Hello Mike , The main control board is on the right side in the back of the unit. look for where the power cord goes iunto the unit after you remove the cover on the back. there should be a large white plastic box on the right side. that is the main control board.
Dec 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung fridge freezer mod no SRS2028 19.3 cu, ft
the water hose runs through the bottom hinge then to the dispenser. take the kick plate off of the unit and then check for leaks. theres a coupling down there that may be yoiur problem.
Dec 08, 2008 | Samsung RS2534 Side by Side Refrigerator
WATER ON THE FLOOR UNDER FREEZER DOOR
dear jim
there is drain line get chocked up with ice.Please open freezer evaporator cover u will find there is ice blocked in drain tray,melt it with hot water,check drain heater attached to the drain tray,if defective replace it,it will work fine
regards
sandy
May 16, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
201 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
