Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What is the physical set up of a network of 8 computers 1 server
I have a Dlink DES 1016D switch i am planning to put up a network with internet and i was told i needed a router. i would like to ask how to physically set up the router with my switch and my server with all the 8 client im going to hook into my network. with another 1 server for managing my network.
    Scholar:
  • 108 Answers
How to connect
connect to what exactly? the physical cable connections? or enabling the set up of the switch in the software?
Nov 06, 2013 | D-Link DES 1016D (DES-1016D) 16x10/100...
Dlink DES-1016D switch will support CAT6 cable or not
Yes. Cat 6 is for 1000Mbps / 1Gbps, and is backwards compatible. It will simply default to port speed on unit.
Nov 19, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have installed dlink 1016 10/100 Switch I have two computers and one dsl router connected to this switch but i am facing slow internet problem. when i connect my pc directly with router it works fine...
you'll probably find the router is set up to ignore ping requests, most are by default, for better results, try pinging a website and compare the results both with and without the switch. The switch shouldn't make any noticable difference to your connections, I use one and there's not perceivable difference in performance.
Apr 19, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I want to know the ip config for this brand i have 15 computer
Hold down the rest switch on the back for 30 seconds. Go to start, run, type in cmd and hit enter. When the dos screen comes up type in ipconfig. This should give you the gateway address for the router. I think the standard ip for dlink is 192.168.0.1
May 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
440 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
