Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
The problem is that the antenna jack on my pioneer deh-112e doesn't match the antenna part on my 2001 renault clio hoow can i adapt it?
    President:
  • 1,990 Answers
Wal-Mart Or Schoche.com has the Adapters that you need for this Repair. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Posted on Jan 29, 2009
Renault clio radio colour code wireing
Yes you can buy an adapter, they are cheap, have a look on ebay
Mar 08, 2015 | Renault Clio Cars & Trucks
I just installed my Pioneer DEH-X6500BT for my 2004 Subaru Outback. However, the radio reception is very poor. The radio sounds very staticky
I suspect that the antenna connection is not completely connected. If an adapter was necessary, check that as well. Good luck!
Jan 20, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Hi, Need radio code for my Renault espace(2004)
The simplest guide to unlock your espace stereo codes:
http://car-radio-unlock.blogspot.com/2011/05/clio-radio-code.html
Jun 21, 2010 | 2000 Renault 181
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
Can pioneer premier iii head unit use a ipod
Here is the link for your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-P6800MP/index.html
you can use an adapter from ipod to rca jacks and go through the aux input, then just select that source.
Cheers!
Oct 18, 2009 | Pioneer DEH-P6800MP CD Player
I want to connect my ipod to the aux inputs on back of unit
Hello gcd_sun,
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Hope this helps.
Sep 10, 2009 | Pioneer DEH-1500 CD Player
Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
Aug 17, 2009 | Pioneer DEH-P6400 CD Player
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
How to wire into a renault clio mk2
should plug straight in / there should be 2 connector blocks one with all the power leads and the other(8wires) for the speakers
Jan 19, 2008 | Pioneer DEH-P6600 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
102 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
