Question about Rose Allows you to access your computers or servers locally or across your network using IP (internet pro... Router (UL-QV3)
What is the physical set up of a network of 8 computers 1 server
Hi I have a Dlink DES 1016D switch with 16 port i want to set up a network of 8 computer client with 1 server with the use of a switch,i was told i needed a router i dont know what router i need and how to set up it with the switch along with the server with an internet connection.
    Scholar:
  • 108 Answers
Dlink DES-1016D switch will support CAT6 cable or not
Yes. Cat 6 is for 1000Mbps / 1Gbps, and is backwards compatible. It will simply default to port speed on unit.
Nov 19, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Sometimes the 8 ports 1-8 stop functioning and sometimes the other 8. Presently half the switch is dead and only ports 9-16 are functional. The switch is atleast 5 yrs old can it be repaired. Rgds and...
Yes it can be repaired. You will need to hunt around for a circuit diagram for it. I have four of these old things in commission at home here and this exact thing happened to one of them. I ran a multimeter over the power supply circuit board (top left) and found one of the capacitors out of spec. The resulting limited power to the rest of the unit meant that it couldn't cope with traffic on all ports. Replaced and fixed the problem. Needed soldering iron and multimeter. Good luck, hope this helps.
Cheers
Mark Vincent
Jul 06, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to connect a lan
Just connect your router into port 1 and rest of your devices on the other ports. Its just plug and play. Im assuming your router is a DHCP server. If not, configure all your devices to static IP
Aug 01, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
All 16 ports are not working
How are they not working?
Check to make sure it is plugged in. Also, try using a different Ethernet cable if you are using the same one to test all ports. If the problem is you are not getting a connection to the internet or something, make sure the router is plugged into the switch and that you have properly set up your network.
Mar 31, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I want to know the ip config for this brand i have 15 computer
Hold down the rest switch on the back for 30 seconds. Go to start, run, type in cmd and hit enter. When the dos screen comes up type in ipconfig. This should give you the gateway address for the router. I think the standard ip for dlink is 192.168.0.1
May 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Rose Allows you to access your computers or servers locally or across your network using IP (internet pro... Router (UL-QV3) Logo
205 people viewed this question
Top Rose Computers & Internet Experts
john h
Emily snow
Lewis Potter
Lewis Potter
Are you a Rose Computer and Internet Expert? Answer questions, earn points and help others
