Question about Mantis 4-Cycle Tiller
4 stoke mantis tiller, loud noise not in engine, maybe the clutch
This noise has gotten steadly louder, a dry bearing type noise
it is not the gear case, it happens all the time even at idol.
    President:
  • 2,976 Answers
If you can get to the dry bushings, DuraLube pump lube will fix your problem. It is available at most automotive stores and departments for $8 -10. I've used it in areas where I had to lube every 10-20 working hours. Now i can go 200-300 working hours. You can also add 2 or 3 ounces to your crankcase oil.
Posted on Jan 29, 2009
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
My Mantis Tiller won't start and there is grinding type noise when I try and start it. I recently did some very lengthy trench digging over a period of about 2 months.
It sounds like the clutch springs may be overheated and the clutch shoes rub while you try to start it.
If you loosten the screw that holds the engine to the gear box you can try to start it without the clutch and see if that is it.
Good luck
Apr 08, 2011 | Mantis 4-Cycle Tiller
I have a mantis tiller, the tines won't turn, the engine IS seated to the flange. any ideas on a fix?
If the motor rpms up without drag it might be a bad gear in the transfer case or a broken cable if it's a cable drive, could also be a bad or stuck clutch. Hope this helps
Apr 27, 2010 | Mantis Tiller Tines #1622 00 02
Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Jul 05, 2009 | Mantis 2-Cycle Tiller
Mantis tiller blades
Common problem with these small tillers.
The gear box needs replaced or repaired.
But first try removing the muffler and see if it helps any as it could be the muffler is stopped up since it runs a gas/oil mix.
Jun 24, 2009 | Mantis 2-Cycle Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Mantis 4-Cycle Tiller Logo
330 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
