Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
Water is leaking from the unit.
When I fill the reservoir, water leaks from the back of the unit onto the countertop.
  • Anonymous Mar 16, 2009
    Water is leaking from inside the unit somewhere and flowing onto the counter top...
  • Anonymous Mar 31, 2009
     I find water under unit all the time. Sometimes seems to happen when unit is not in the process of brewing. Just always is there. Is the unit kaput?? Time to buy a new one?
Bunn makes a repair kit for this problem, Call them at 1-800-352-2866
They send the repair kit free,
Posted on Apr 21, 2009
  • fisherpeg Mar 17, 2011
    I truly love this coffeepot. I sure hope this stops it from leaking. Thanks
It is possible that the gasket and washer connecting the basin to the tank have deteriorated. I am trying to find replacement gasket and washer but not having any luck.
Posted on Feb 28, 2009
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    How do I fill the water resevoir for the conair steam mist curling iron??
    HOW TO FILL THE WATER RESERVOIR: 1. Remove water reservoir cap (the one at the end point of the hot part) and unscrew steam activator in order to fill. CAUTION: Steam activator is very hot while in use. Do not touch. 2. Fill reservoir with water. 3. Place cap back onto unit making sure water is not leaking out. NOTE: Fully immerse the wick and wick holder in water for at least 15 seconds before use.
    Jun 26, 2011 | Conair Health & Beauty
    WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
    Below are solutions for a leaking coffee maker and how to decalcify the machine?
    Tools and Materials needed to fix this problem are as:
    * White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
    Step 1 - Clean
    If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
    Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
    Step 2 - Pump Valve
    Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
    Step 3 - Brew Switch
    Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
    Step 4 - Tube Connectors
    If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
    To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
    1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
    I hope the above helps....
    Good luck.
    Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
    Water keeps leaking out onto countertop, even when off. Doesn't matter if reservoir is at max or min.
    I had the same problem.. I took the clear rubber grommet piece off and added an additonal o ring I had left over from a pur water filter kit and it stops the water from leaking. What does annoy me is that it only pushes water cleanly through for about 30 sec then it drips very slowly for the remaining brew to fill two full shots (I like mine big).
    Jan 17, 2010 | Hamilton Beach 40714 Espresso Machine
    PUR 200 Water Cooler leaking from the back (under the reservoir)!
    I had a similar problem. My PUR 200 water cooler was also leaking from back. The reservoir had crack in it. Since replacement part is not available. I used Super Glue and it is working fine now.
    Aug 11, 2009 | Kitchen Appliances - Others
    Water goes in reservoir, not thru hose to sump pump, leaking
    blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
    Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
    Saeco Vienna leaks water from water tank
    Sorry for the delay in response but I just read your complaint. I had similar water leakage issues and mistakenly replaced a bunch of stuff without stopping the leaks, until I discovered the real problem; the O ring seal that the water reservoir sits in located under the reservoir where it mates with the machine. Easy to replace and cheap. No leakage problems since I both replaced the O ring and started the routine of not taking off the water reservoir to fill it, but leaving it in place and filling it from a bottle. That technique does not any wear at all on the seal ring and so it won't leak in the future.
    The item is called a "Saeco-water inlet valve gasket" , has a part number of NM05.006 and costs $7.50. I purchased it from Services Unlimited located at 650 N. Cannon Ave. WH-305, Lansdale PA 19446; phone 215-361-7000 Fax 215-361-7434, e mail granita@rcn.com but you can find it at any authorized dealer, I am sure. I ordered two and with shipping the cost came to $21.50.
    You can request a fax with a parts diagram and listing, which I found most helpful in diagnosing issues and see where stuff goes..
    Hope this helps you..
    George W Conrad
    Feb 18, 2009 | Saeco Vienna Espresso Machine
    LEAKING WATER
    Does the other unit have a drain?
    Jun 15, 2008 | Fedders A6P09S2A Air Conditioner
    Leaking
    i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
    Feb 25, 2008 | Solis Master 5000 Espresso Machine
    Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
    864 people viewed this question
    Top Bunn Coffee Makers & Espresso Machines Experts
    Kelley Hopper
    gbob59
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
