Question about Compaq Pavilion ZT3280US Notebook
Hp dv8000 reimage problems
Boot hdd (hdd 1) boot partion is corrupted (prob bad sectors) hp reconfig partition seems good on hdd1. 2nd hdd seems fine. imaged a new hdd 1 from reconfig cd. No drivers where loaded. Including NIC. What is the best place and way to get either online to download drivers or access the drivers in the reconfig partition
  • 1,906 Answers
HP.com
:: "support/Drivers"; Put in your model # then your Operating system then:download updates/drivers
Posted on Aug 26, 2009
I have an HP Pavilion Elite m9250f Desktop PC which which was working fine till a few weeks ago when I turned it off. When I turned it on again it went through the booting process then the screen went...
Your hard drive is dead, you can pull it out and turn into a USB drive, (15 bucks, Newegg), plug it into another to see if you can access it. If its a SSD drive, your done, hope you have everything backed up, because when they go. their gone. get a new had drive and do a fresh install.
Apr 15, 2017 | HP Pavilion Elite M9250F Desktop PC
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Hope this helps you
Apr 06, 2011 | Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2...
Fujitsu lifebook will not bootup. Message says "operating system not found."
Couple of things here, 1. Your os/nos is missing or 2. your boot files have been moved to another partion and the server has not been directed where to look.
Solutions: reinstall the os/nos or find the correct partition which has the boot sector and direct the server to boot from that partion. (This partition should be partition 0.
Good Luck
C2Solutions
Jan 23, 2010 | Fujitsu Siemens Siemens PRIMERGY B210...
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
HP Desktop
Hi
The same thing happened to me also with one pc I have running windows vista ultimate and freeBSD.
Delete all partitions, format to NTFS and do a clean install of windows, and for a 80GB drive just use one partition for the whole drive and install windows on that drive, set the bios to boot from CD and during install windows will use the whole drive as 1 physical drive.One Partition and you should get about 72+GB MIN. You will not get a full 80gb due to the way windblows measures a mb= 1000b rather than 1024b and also special hidden files, recycle bin, drive info, and partition info, boot sector etc.
HTH
Zues
Dec 17, 2008 | Magic Computers & Internet
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Compaq Pavilion ZT3280US Notebook Logo
177 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
