Question about GE 24 in. GLD5500L Built-in Dishwasher
My ge dishwasher will not start its cycle when I press "Start" - the screen that usually says the time remaining says what appears to be "lh" instead. I do not see in the manual what this means!
Problem solved - I turned the power to te dishwasher at the breaker, waited about a minute, and then turned it back on. Everything worked fine after that.
Posted on Jan 30, 2009
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
I am getting a 5H in the panel where the time cycle usually is and when I hit start it won t start
I think your dishwasher is in delay start mode. Some dishwashers can be set to start at a later time say for instance while everyone is sleeping. See if your control panel has a button that says delay start. If YES--just keep pressing it until it clears. Some go as high as 12H which is a 12 hr delay.
Feb 28, 2015 | GE Dishwashers
What does a 5h code indicate
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
Feb 07, 2015 | GE Dishwashers
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
Screen frozen with 1 hr remaining
unplug it for a few minutes, see it that resets it.
Mar 02, 2010 | GE Dishwashers
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Water Remains in dishwasher after cycle
Few things to check....if it is a push button....press the start button and then press the cancel button, the drain should engage. if it is a timer setup, turn it to the cycle start and close the door, will drain unit. If water doesnt drain and you hear a pump running then you have a clog.....be sure to check your disposal plug,where the drain hose connects to. if water just appears in d/w while not in use check the drain hose position....should loop up from the drain to prevent backwash into d/w.
Jun 10, 2009 | Dishwashers
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Profile built in dishwasher problem
Try cutting the breaker off for 5 min, This will reset the control.
Mar 14, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE 24 in. GLD5500L Built-in Dishwasher Logo
299 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
