Question about Sharp AL-1655CS Laser Printer
Al sharp 1655cs error system H4-00
Impossible to work on without clearing it.
5 Suggested Answers
  • 2072 Answers
SOURCE: Sharp AL-1655CS
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display1.gif should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies1.gif.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Jan 10, 2008
sabharish
  • 297 Answers
SOURCE: My Sharp Al-1655CS Display is frozen
Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Thank you!
Sabharish
Posted on Jun 19, 2009
  • 224 Answers
SOURCE: need driver - software cannot find disk for Sharp
http://www.sharpelectronics.info/Software.aspx
Posted on Apr 09, 2010
  • 1335 Answers
SOURCE: I can not install driver printer sharp al-1655cs
Try the driver at
http://www.massdrivers.com/dir/249878.html
for your Windows 7 system.
Posted on Apr 15, 2010
I have sharp AL-1655CS i plug it in and get
Hello sir; You do need a reset procedure as follow; press "#", "*", "clear" " *" then enter 14 press print.
Jan 27, 2010 | Minolta Office Equipment & Supplies
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Makes noise and will not copy
Check the scan head lock. It can easily be locked or unlocked. It is used to protect the moving parts inside the machine when it is moved/transported. Someone in our office was just making copies and ttapping their fingers on it and they locked it without even realizing it. it is under the top of the machine where the paper comes out. sometimes they are a slide or turn knob.
Dec 30, 2009 | Sharp AL-1655CS Copier
My Sharp Al-1655CS Display is frozen say: system error (H4-00)
Thank you!
Sabharish
Jun 19, 2009 | Sharp AL-1655CS Copier
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
Dec 08, 2008 | Sharp AL-1655CS Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS ERROR MESSAGE
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
Mar 17, 2008 | Sharp AL-1655CS Copier
Sharp AL-1655CS
Jan 07, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Laser Printer Logo
295 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
