Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore washer and its making a weird noise and the center spinny thing wont spin what do i do
  • 943 Answers
Hi the problem is with the motor coupling,It drives thr tranny .Here is a site that will help you.Ifyou need more info I am here to help you. The applianhttp://www.applianceaid.com/procedures.html
ce doc
Posted on Jan 31, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
My kenmore washer model 110 20022011 is making weird noises. Its not just regular sounds that it makes. Has happened first time in 4 years.
many things cause noises coins going between inner basket and outer shell . bearing going out make odd noises also
Apr 10, 2015 | Kenmore Washing Machines
Kenmore washer will fill and that it when it goes to start spinning it makes a weird noise
Sounds like the controller behind he knob is shot. May be cheaper to get a new one or look for a new used one on craigslist. If you google the model number and addparts list it should bring up a link to the sears parts list. Youcan then gogle the part # for the controller module and see what it costs.
Dec 02, 2013 | Kenmore 22422 Top Load Washer
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Washer does spin and it makes a weird noise
Not familiar with model but must cases its the drain pump blocked. water needs lowered before spin cycle works. Lay drain hose out the door to empty. Drain pump is down bottom beside where this hose comes out. Undo the filter bung there and clean out
Dec 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 70 Series top load washer makes noise during spin cycle
There are three springs under your machine. two that look the same....one on each side of the tub. and one in the back of the tub. it is common on machines that are a bit older for the rear spring to wear itself through the metal at the bottom. if this is the case, it is best to get a new spring and just drill another small hole next to the old one. you might be able to get by with using the old spring for a bit longer....just drill another hole.
Dec 27, 2008 | Kenmore 23822 Top Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
