Question about Linksys WRT54GS Wireless Broadband Router 4 x 10/100Base-TX 1 x 10/100Base-TX IEEE 802.11b/g Wireles... (WRT54GSFT)
Linksys wireless-g hi bassicly i have got a linksys router and im trying to conect to a friends computer a few doors away hes give me his passkey but when i connect it cut off after about 1 sec plz help danny
  • Anonymous Dec 13, 2008
    how do I connect a router
    to the modem and computer
    President:
  • 2,961 Answers
Ok, you seem to be going around it the wrong way round, if you are trying to connect to your friends network you would not connect to his pc you would connect to his router, so you cannot use your router to connect to his. assuming you have a wireless network adapter, which you must have, you simply connect to your friends router via your pc and not your router, you cannot have one router connecting to another, only signal boosters. when your'e network adapter detects a network, select your'e friends and then enter the passkey when prompted, so turn off your router,as it can only be used for your own network, as it musn't be connected to your modem, or else you wouldnt need to connect to your friends. If you want to connect to your friends pc for file sharing make sure he has is sharing set up and you both have the same workgroup name e.g. mshome
Posted on Jul 27, 2007
Can you send me instructions on how to secure my linksys 2.4GHz router so no one can access it from another location
Hello
Ok, at the link below you will be able to get instructions on how to secure your Wireless network.
Click HERE to navigate to the page.
Kind regards
Andrea
Aug 14, 2010 | Linksys Wireless-G Broadband Router
Intel pro wireless 2200gb 802.1.11g/b sees the wireless network but is unable to obtain an IP address, I have two other laptops that conect to the linksys router just fine.
if you are using a passcode that is wpa for your security, check the version. if you are using wpa2 the card you are having issues with may not be able to support that passkey type. This will result in the problem you are having. Try the passkey as WPA1 or on some routers they give an option to allow 1 or 2.
The only other thing that can cause it, is mistyping the passkey so as long as the computer that you are adding doesn't require its mac address to be entered into the routers allowed clients mac table
Feb 12, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
WE LOSE CONECTIONS TO THE SIRED COMPUTER IN THE
upgrade the router firmware but first reset ur router and then do that
Dec 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I have an router and im trying to reset it but i dont have the disc can i get it online
There is a RESET pin hole on the back of the Linksys wireless router.
Press and hole for 30 secs with the power on.
It will return to the factory defaults.
The reconfigure the Linksys :-
Connect a LAN cable fron your computer to the Linksys and open IE browser, the configuration URL is http://192.168.1.1
The login = admin and the PW = admin
Nov 02, 2009 | Linksys Wireless-G Broadband Router
My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Wireless ir conected, but don't works
My name is ArmyMason, I have a suggestion for you. In Internet Explorer click on file and see if Work offline is checked. If it is unchecked it and try again. If this solution doesnt work might I suggest using our premium service or live chat.
Thanks,
ArmyMason
Feb 24, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Cannot connect xbox 360 to wireless router
If you use DSL I would also check to make sure you are not being port blocked by your ISP. Some will block you if you exceed bandwidth on a particular port rather than throttling you or shutting you down entirely.
Dec 29, 2008 | Linksys Wireless-G WRT54G Router
Secure internet connection
To secure a wireless network connection, either WEP or PSK has to be enable in the LinkSys router and a passkey designated/chose. This passkey must then be likewise encoded into your HP notebook wireless networking.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Hi i have a problem conecting my lap top ho nx5000 to wirless mode can you help me
If your running WinXP you should see an icon on the bottom right near the clock with a wireless icon. Double click on it, should now open up a windows showing a list of available wireless networks to connect to.
If you have your own Wireless router in your place find the name of that ID whatever you had set it to. If you bought a Linksys router it would say by default Linksys. If it ask for a passkey enter the passkey you had setup on the router.
Now if you can see any wireless networks or you do but can't connect see if your laptop has a on/off switch for your wireless card. If so switch it on and bam wireless freedom you have.
Aug 21, 2008 | HP Computers & Internet
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
