Question about RIM BlackBerry 8800
Blackberry error 348
Any hope to recovering from this without having to do a fresh re-install? Havent backed up in about 1-2 weeks, hoping not to lose data.
  • RIM Master
  • 4,338 Answers
Hope that his helps:
Here is how I was finally able to get my phone to work.
When the battery was very low, the phone would no longer activate the radio function. I found that when the radio was not trying to connect to the network, I could enter my password and adjust my network settings.
I thought the issue may have had to do with the "data services" function so I diasbled this function.... and the phone worked with this function off (after a light recharge).
Just to confirm I had found the cause of the lock-up, I enabled the data services again and the phone immediately locked again.
Here's how I was able to work around it.
Go to the "manage connections" icon and open it up. Select "mobile network options" and the top selection should be to turn the "data services" fuction on or off. What I found was that once this was off, the phone worked just fine but obviously all access to e-mail and other web-services was shut down. At least I had my phone......
If you are not able to get to the data services area because the phone keeps locking up at the "error code 348" screen (grey screen of death), then you can try this also if you have your security on the phone set to allow phone calls while its still locked.
Hit the "R" button to reset the blackberry or if this doesn't work, remove and reinsert the battery and it will reset. Note, you may have to use the "on" button to get the phone to turn back on after removing and reinstalling the battery. As the phone is going through the process of starting back up, and before it goes back to the error code 348 screen, you can do the following....
At least this worked on my unit.
At the Verizon screen which was the last screen to appear before the phone would go back into error mode, I was able to select the option to "place call".
I only had about 10 seconds to do this and get a call going before the phone would lock up again so choose a number and call it quickly....
For some unknown reason, the phone will not lock up at the "error code 348 screen" while a call is in progress. So I called the office and then hit the "select" button (one with all the little dots on it next to the mouse ball) and chose the option to "unlock" the phone. Once unlocked I could get to the "manage connections" icon as noted above and choose to shut down the "data services" function again.
Sorry for the long-winded explanation.
This was a major headache for me when I arrived in Puerto Rico and could not access any numbers on my phone because it kept going back to the error code screen every time I reset it. When I figured out that it was simply a limitation or issue with the data services function and I could use the phone and access my call logs, contacts list, etc., even without e-mail this was a great success.
Hope you find this useful.
As a side note, if you don't have your phone set to "allow calls when locked" in the security section of your settings in the options section.
If all else fails, you can get to area where you can unlock your phone if it sits long enought at the error code 348 screen. The unit will get to a point where the battery is too low to allow calls but you can still unlock it and maniupulate the settings. If the phone is totally dead, just charge it for a few minutes and adjust the settings before it charges enough to try to reconnect to the network.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 09, 2009
I have a blackberry which shows jvm 517 error and reset .how do I take care to turn it on
Hello there, the error message indicates a corrupt OS. Depending on the model what you have to do is visit the blackberry download website search for your blackberry make and model and download the firmware which is recommended for use by your unit.After downloading it install on your PC and run. This process should install the firmware freshly on your device. With a new firmware installed the problem should automatically be solved. Usually the problem arises as a result of either a viral infection on the unit or probably some malfunction from the firmware.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Aug 23, 2011 | Cell Phones
My blacberry wont turn on, just a white screen saying app error 523 reset help graaaaaaaaaaaaaaaaaaaaaaaaaaaa
What you will need to do is reload the Operating System (OS) you will need to refer to carrier to find out the most recent OS for your model. If you havent done so already you will need to install the Blackberry Desktop Manager (BDM) (hopefully you have and you back up and sync on a regular basis) once you download and install the software to you computer from your carriers preferred way (this is the only for sure way to get the right OS) open BDM plug in your device and open application loader and follow the wizard to install the os to the blackberry (if you have not backed up recently you may loose all info on your phone
Sep 20, 2010 | Cell Phones
My blackberry 9000 says JUM Error 102 Reset only i cant find my cd that came with it how can i fix it to work again
With any JVM Error you are going to need to reload the operating system to your device, this process is slightly different with each carrier, so it is important to contact them during the process, first (if you have not done so already) Download and install the Blackberry Desktop Manager to your computer, The Desktop manager can be obtained from blackberry.com once installed you will need to download and install the most up to date software from your carriers website,then follow the instructions to install the software to your phone, now unfortunatly your going to lose any information you have not backed up to your computer
Hope This Helps!
William
Sep 06, 2010 | RIM BlackBerry Bold 9000 Smartphone
I have a blackberry storm. When I woke up this morning, I found an App Error 523 Reset on a white screen. When I pushed the reset button, my phone loaded, but then it said Uncaught Exception 8>=8 and...
HI,
I suggest the following steps (insert plenty of reboots of your PC...not just restarts, but full power down reboots). Also, it is advised that you be logged into the PC on an account with full admin rights. Further, under Vista, use the "Run As Administrator" option for everything. If you have never installed the Desktop Software to your PC, then skip steps 1 and 2.
1) Remove your device OS update package from your PC (add/remove programs)
2) Cleanly uninstall the RIM DTM software:
  • KB02206 How to perform a clean uninstall of BlackBerry Desktop Software
3) Get a fresh download of the RIM DTM software:
  • Choose the version that is newest and (if applicable) compatible with your PIM (if you are synchornizing via USB):
  • KB12268 Applications supported by BlackBerry Desktop Manager for synchronization
4) Download (to your PC) a fresh copy of your device OS package from your carrier:
5) Install DTM to your PC
6) Install (also to your PC), the device OS package
OK...next, follow this KB (including the other links within the KB) for recovery from the 523 error:
  • KB11816 Error "523 app.error.Reset" appears on the BlackBerry smartphone
Good luck and let us know!
Jun 22, 2010 | RIM BlackBerry Storm 9530 Smartphone
Jvm error 513
With any JVM Error you are going to need to reload the operating system to your device, this process is slightly different with each carrier, so it is important to contact them during the process, first (if you have not done so already) Download and install the Blackberry Desktop Manager to your computer, once installed you will need to download and install the most up to date software from your carriers website,then follow the instructions to install the software to your phone, now unfortunatly your going to lose any information you have not backed up to your computer
Hope This Helps!
William
Jun 18, 2010 | RIM Blackberry 8700 Cellular Phone
I have an app error 523 ive reset it and it dont work
Hi, On the BlackBerry smartphone, the 523 app. error Reset error message appears after pressing the Mute button, accessing an application, or performing a hard reset: To resolve this issue, first perform a hard reset. A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps: 1) Remove the battery cover from the back of the BlackBerry smartphone. 2) Remove the battery, and then reinsert it after a few seconds. 3) Replace the battery cover. If this does not resolve the issue, the BlackBerry Device Software must be re-installed. Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Proceed to open and run the application loader tool. If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps: 1. Remove the battery and run loader.exe from C:\program files\Common Files\Research In Motion\AppLoader. 2. Remember to reinsert the battery after the loading operations begin. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a Dell Inspiration Laptop (8 weeks old) that will not restart windows after shutting down suddenly with a low battery. Hardware diagnostics all pass. Neither a repair or restore using the Vista...
Your 8 week old laptop should still be under warranty. ( I understand that the minimum warranty is one year, and maybe it depends on the country).
Check your warranty and send the lemon back for a refund.
Hope it helps
Aug 28, 2009 | Dell Computers & Internet
Blackberry jvm error
The very same thing happened to my Blackberry Curve. The system has been completely wiped-out. The service is still there but you need to download the software to your phone again. You can fix it if you have access to the internet without the CD. Go to www.blackberry.com. then click on Software, then click on Device Software and follow the instructions from there( your phone must be connected to the computer while doing this with the USB cord) This will reload the software back on to your blackberry. Also, beware, you will lose all of your contacts that you had previously stored in your phone. I am so sorry that you are experiencing this on your vacation. Hope this helps.
Jul 17, 2009 | RIM BlackBerry Pearl 8100
My 8703e has device error 348. wht can i do?
If you have the Blackberry desktop software.
attach your blackberry to the computer and go to application loader.
click on application loader.
make sure everything is check and this will restore your phone.
I believe this will clear up your problem.
it will do a fresh install of everything.
you can then import your sim contacts and you should be set.
May 17, 2009 | Sprint BlackBerry 8703e Phone
JVM Error 531
Hi, Please do hard reset,
If still you get the error message then please,
Upgrade the latest version of BlackBerry Device Software. Hope this information will be helpfull to you
Mar 16, 2009 | RIM BlackBerry 6230 Handheld
RIM BlackBerry 8800 Logo
693 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
SANTHOSH
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
