Question about Dryers
Getting Dryer Through a Narrow Doorway
We have an old coin-op gas dryer in the basement of our apartment building. We went to replace it with a GE DCCB330EG, which the spec sheet shows is 25-1/4 inches deep. It showed up, and has a panel (galvanized steel, not painted) at the back that is almost 2 inches beyond the 25-1/4 inch spec for the depth. In other words, the enamel parts total 25-1/4 inches, and this is another 2 inches beyond -- too wide to get through the doorway and down the (also narrow) stair case.
The delivery guy wasn't willing to take the back panel off and the dryer went back. I wondered if we tried again, do you know exactly what is under that panel? Does anything protrude past the panel once it's been removed? Does it have any electrical or mechanical connections to the dryer or is it merely insulation, etc?
If you have any other suggestions, please advise. The top of the staircase is 26 inches wide, perhaps 26-1/2.
  • Fitter Man Jan 30, 2009
    Just to clarify, the doorway is narrow, the staircase (at the top) is even narrower -- it's 26 or 26-1/2 inches wide! The wall at the top of the staircase was built out for some reason so while your suggestion is part of the solution, short of tearing the wall out at the top of the staircase and then putting it back together, I'm still unable to get a dryer down to the basement.
  • 150 Answers
Remove any doors on the way down.Sounds like an older house that forgot progress (we make things bigger now),you could take off the exhaust vent also.
Hope this helped.
For more help go to live chat.
Posted on Jan 30, 2009
No heat in coin op dryer
Check gas supply may be off!
Feb 27, 2013 | Roper Dryers
GE commercial coin op dryer only runs when start button is depressed. The second you let off the buton the dryer stops.
hows the timer unit on doing when you push on it the timer is suppose to start..
Apr 15, 2011 | GE Dryers
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
Dryers Logo
138 people viewed this question
Top Dryers Experts
