Question about Philips 47PFL3603D LCD TV
Static on sound system (47 in. HDMI) TV SET
Spoke with Ken this morning about a problem with my sound system. He said that I had to download a zip file. I checked your website and I couldn't find such a file. Need some to locate this file. Thanks, Ellis Seals
Model # 47PFL3603D/27
  • cjr517 Apr 26, 2009
    I lose audio and a loud static sound comes on. This happens only on standard definition channels. High definition channels are good. The audio comes back when I change to a high definition channel,but I lose audio again in a few minutes after I change back to a standard definition channel. I am connected to directv.
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Jan 01, 2011 | Televison & Video
Sony 60 in LCD edge LED TV: Hooked up new TV to a cable box - have HD picture but no sound. TV speakers say on. Makes sound when TV channel is changed (static). But nothing when input cable (via HDMI) is...
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Aug 12, 2010 | Sony XBR60LX900 60 in LED TV
My proscan 32lb30q won't allow me to switch inputs to HDMI. It will only allow me to go between composite and tv channels. I'm trying to set up my laptop to connect. It's not a connection/cable problem,...
First, verify that your computer is sourcing video through the HDMI port rather than looking for an input from it.
What happens if you try to select an HDMI input on the TV with no HDMI cable connected? It should select the port, then complain about "No signal." If you get that, turn off the TV and computer, connect the HDMI cable, turn on the TV first, then the computer.
There are certain HDMI input chips on the market that are very vulnerable to static electricity damage, and some cheap HDMI switches will conduct a static discharge from the switch mechanism to the HDMI lines (a friend blew two chips that way, then he realized both times the input went out when he used the switch). Use a direct cable connection if possible, and avoid putting a fingertip into the free end of an HDMI cable when the other end is the only one connected. Symptoms of static electricity damage may include "no signal" when an active signal source is connected, or some sort of data format error message. I don't know if your TV is programmed to lock out bad ports; I would think there would be some sort of fault indication to go with the lockout.
Jul 09, 2017 | Proscan 32LB30QD 32 in. LCD TV
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
When I plug my lap top into my tv via hdmi cable I get a picture but I do not get any sound. I have a year old LG 52" LCD tv
My MacBook laptop and probably others do not output sound on its mini-DVI connector and thus not into the HDMI adaptor. I would have to use the wired sound output or the optical output--same hole--into the sound system. If you have a DVI-HDMI adaptor, then that is the problem, there is no sound wiring on the DVI side. Same for VGA, which does not have digital video only analog.
Apr 10, 2010 | LG Televison & Video
the patch for this tv is actully a firmware upgrade, now firm ware upgrades can sometimes become difficult to perform and should be done by a philips auth servicer. they have access to this materials and if something goes south they have access to tech support. If not done in the right way you could make the tv even worse. It should not cost more thn 125.00 for a tech to do this. better be safe than sorry, and i have me alot of sorry ones.
Jan 29, 2009 | Philips 47PFL3603D LCD TV
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Philips 47PFL3603D LCD TV Logo
356 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
