Question about ASUS S 1000 Notebook
Removing the Web Mail Icon from the Favorites Tab
The Customize Icon in the Favorites Tab does not display the pre-loaded Icons in the Current Favorites window. This means I can not remove the Icon from the Tab.
  • Anonymous Mar 17, 2014
    How do I add msg. icon to my favorites
  • Anonymous Mar 31, 2014
    My favorite list has things on it I do not need any more how do I delete them
How can i retrieve my mail icon
The use of desktop icons has served to simplify opening and using programs in Microsoft Windows.
With a simple click of the mouse, an entire program can be opened.
Unfortunately those desktop icons can also be deleted, sometimes accidentally or sometimes by the desktop cleaning utility that runs in Windows, but there is a simple process to recover desktop icons.
Just follow these steps.
Click it without a ticket.
To restore lost desktop icons, first place your mouse anywhere in a blank area on your desktop. Once you have placed your cursor in an unused area of the desktop, right click.
Check the pop up.
Once you have right-clicked your mouse in the unused area of your desktop you will receive a pop up menu or prompt.
Choose "Properties" by left clicking it with your mouse.
Grab that tab. Once you have clicked on "Properties" you will receive a dialog box.
Click on the tab labeled "Desktop."
Customize it.
Once you have clicked the "Desktop" tab choose "Customize Desktop" which will prompt another dialog box to open.
From there click on the "General" tab.
Restore order.
After you have clicked the "General" tab you will see a list of icons.
Simply choose the icons you want restored or placed on the desktop and then click "OK."
That's it.
You have now successfully restored your desktop icons.
May 04, 2014 | E-Machines eMachines Desktop PC
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Yahoo how do i get icon for yahoo e-mail on start screen
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Open a web page sign in to your yahoo email account
right click in yahoo select add to favorites this will add yahoo email to favorites for access from the favorites drop down list.
Oct 17, 2013 | Computers & Internet
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
All icons on my pc desktop are always in selected mode(these looks like when we select an icon to do something,that means these are shaded with blue color,but i can select 1 or more icons at a time as...
Hi
If you have any web content on your desktop, transparency won't work.
To check for web content: Display Properties>Desktop>Customize
Desktop>Web - make sure all checkboxes are clear.
then
1. Click on Start
1. Choose Control Panel
2. Click on System Icon
3. Choose the "Advanced" tab, click "Settings" under "Performance"
4. Under the "Visual Effects" tab I Chose (checked) Use Drop Shadows for Icon Labels
OR 1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then click System.
3. On the Advanced tab, click Settings under Performance.
4. Click to clear the Use drop shadows for icon labels on the desktop check box, click Apply, and then click OK two times.
5. Close Control Panel
May 10, 2010 | Microsoft Windows XP Professional SP3 Full...
I have a laptop that will load up but with no desktop icons
that means that the original file or the path of the shortcut does not exist. note down the type of shortcuts you are facing problems with. if it is regarding My computer, My documents, etc. delete the shortcut files. right click on the desktop then go to properties.Click on Desktop tab then click on customize desktop button at the bottom left. under desktop icons, click on all the boxes to activate the icons to appear on your desktop.
cheerz.
Feb 21, 2010 | Microsoft Windows XP Home Edition
Icon changing to generic windows
Steps for Changing a System Icon:
BEFORE YOU BEGIN!
Right-Click your desktop and choose "Properties". Then follow the steps below.
1. Click on the "desktop" tab at the top of the Display Properties window.
2. Then click the "Customize Desktop" button.
3. A Desktop Items window will open. Choose the "General" tab.
4. From the dsplay of system icons, click on the icon you want to change making sure it's highlighted.
5. Click on the "Change Icons" button. This will allow you to browse your computer for the icon you want to use as a replacement for your System Icon. (remember to click "OK" and "Apply Changes" once you have chosen a new icon).
Jan 30, 2010 | Microsoft Windows Vista Ultimate Edition
Script error, active desktop in recovery mode, how do I fix script error says line 65
PLEASE LET ME KNOW IF THIS HELPS AT ALL
How to enable / disable windows active desktop. Question:How to enable / disable windows active desktop.
Answer:Microsoft Windows XP users
  1. Open the Control Panel.
  2. Open the Display icon.
  3. Click the Desktop tab.
  4. Click the Customize Desktop button.
  5. Click the Web tab in the Desktop Items window.
If you wish to enable the Active Desktop, check My Current Home Page.Add your current home page into your desktop or click New to addanother web page and/or other Active Desktop features. To update thecontent, click the Synchronize button.
If you wish to disable Active Desktop, make sure all checkboxes in this window are un-checked.
Nov 09, 2009 | Compaq Presario 5000 PC Desktop
After os screen appears after a few minutes, the monitor screen is blank. no desktop icons are displayed
hi there..
dont panic do the following sir
--> left click ont he screen
--> go to properties
--> click on desktop tab
--> click on 'Customize Desktop' bottom left side
--> click the icons you want to appear on desktop on 'Desktop Items' Window
--> dont press ok yet
--> click on web tab on the same window
--> un-check all the checked items
--> click ok
--> click ok again
--> you will se the items on screen.
hope it will help you sir
Mar 24, 2009 | ASUS Eee 4G Notebook
Hi. onmy desktop aweb page with msn is stuck in my desktop thanks norman
Disable windows active desktop then reactivate it. That will take care of it. Microsoft Windows XP users
If you wish to enable the Active Desktop, check "My Current Home Page". Add your current home page into your desktop or click New to add another web page and/or other Active Desktop features. To update the content, click the Synchronize button.
Microsoft Windows 98, Windows ME, Windows 2000 users
  3. Click the Web tab in the Display Properties window.
If you wish to enable the Active Desktop, check the checkbox for "Show Web content on my Active Desktop" and select the home page you wish to use as the active desktop.
If you wish to disable Active Desktop, make sure that "Show Web content on my Active Desktop" is unchecked.
Jul 26, 2008 | Computers & Internet
ASUS S 1000 Notebook Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
