Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
The machine is working as we can here it running but it doesn't print or send faxes....the code we are getting is UF-585 (AU) OPT
Can you help us?
    Genius:
  • 2,120 Answers
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Posted on Feb 03, 2009
The lcd screen does not work any more and i cannot fax panafax uf - 585
hi hahudson,
I think you need a physical service of that fax machine.
mastergani
Feb 04, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
Hello i have a panafax uf-280m i would like to
Sometimes you can go to "print reports" then activity report and print your send report
Mar 23, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Manual for panafax uf 585 . it says info code 26 >> replace battery. I dont know where is the socket for battery? Can you please send me a picture for the same or a solution
Hi manish717
You can download a manual free from the following link.
You will have to give your email address.
After downloading, goto page 151 where you will find the answer as how to replace the battery.
http://www.retrevo.com/s/Panasonic-UF-585-Fax-Machines-review-manual/id/313ag417/t/1-2/
Hope this will work for you, Have a Good Day
If this answer helped you, please give a rating
luciana44
Sep 22, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
PANAFAX UF-585
Bad fax stuck in memory. Press:
Fuction
7
6
scroll down to ALL JOB CLEAR
set
Nov 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Warming up non-stop with this message UF-585 (YM) OPT
Open top cover
remove toner cart.
leave cover open
Press:
Function
7
6
scroll down to "all job clear"
(as a last resort choose "shipment set")[sets machine to factory default]
Sep 26, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
UF 585 Fax Machine Message in memory
if its only a few % like 1, 2, or some thing its probably nothin retrievable, you can have a tech come and clear it but if all else is working and the mssage in mem file dosent keep growing try and ignore it till next service
May 05, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
File storage is full
here is the manual, look at page 9 of the e-manual for the function keys.
# 9 Edit file mode ----Print file. ( also shown on pge 81)
shows how to delete the file also.
Good luck
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=412914c5b54b5add014416140dfd72ec&q=panasonic+uf+585+manual
Sep 19, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
269 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
