Question about Dell 1700n Laser Printer
Dell 1700 printer.......the margins shifted to the right during printing and I am loosing part of the print........help!
maan123
  • 38 Answers
SOURCE: HP-1120C print out shift
adjust margine of the printer properties as 0
Posted on Mar 04, 2008
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
babes_ganda0
  • 381 Answers
SOURCE: How do I turn off printer status window that
hello..go (start)up menu then click then find the option (Setting) then click choose (Printer and Faxes) then click.if here find you`re printer name click and sets (Use Printer offline) or (Pause Printing)..Thanks and Good Luck..
Posted on May 11, 2009
SOURCE: flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
Posted on May 29, 2009
  • 13 Answers
SOURCE: Dell 1720 printer prints crooked i.e. left margin
most likely you have a bad pick-up roller. it is inside the printer directly above the paper tray. this is one reason the paper would pull in an angle.
Posted on Nov 14, 2009
I cannot get printer to print documents with equal margins.
Guess you are not using the same page size as the one you've got configured in your computer for printer. ie: you are using Letter and printer is configured to A4
Jul 18, 2015 | Dell Office Equipment & Supplies
HP Deskjet 5650 is printing off-center. The printing field is shifted to the right, so the right margin is non-existent and I lose a bit of the printing. How can I fix it?
I think the horizontal printing starting point can be adjusted by holding down buttons (??) when powering up. Right now my left margin is 3/8 inch too big -- photos have that much white space on left margin with borderless printing. I am trying to figure out the key combination.
Jul 27, 2010 | HP DeskJet 5650 InkJet Printer
Printer will only print from one program (it will not print from microsoft office or anything), however when it does print from this program, the document is overprinted with either computer code (I am...
have you set the dell 1700 Laser Printer as your default printer? Go to printer & faxes, right click on dell 1700, choose "set as default printer"
Apr 10, 2010 | Dell 1700n Laser Printer
How do I Adjust the Printer Margins for Dell 1720 I am printing on insurance forms and the print is too high and to the right
I have found a good manual that can help you easily with the help of pictures.
Click on the link below to access it :
ftp://ftp.lexmark.com/depot/Dell/Dell_1720_Depot_rev061807.pdf
In case of further help let me know
Mar 21, 2010 | Dell Laser 1720 Printer
System shuts down when printing to dell 1700 laser printer
You may have a 'recalled printer' Check out this link!
http://support.dell.com/support/batteryrecall/index.aspx/en/main 1700/1700n Printer RecallIn cooperation with the U.S. Consumer Product Safety Commission, Dell is voluntarily providing the Customers who purchased the 1700/1700n printer (from June 8th, 2004 - August 18th, 2004) a free replacement printer. [Announced September 7, 2004]
May 11, 2009 | Dell 1700 Laser Printer
Dark background on Dell 1700 printing
Faulty (or wrongly) remanufactured cartridges can produce a 'background' to a print, which can be even across the page or have a mottled effect.
Do a printer self test page (press the arrow button).
put the old toner cartridge back in and do the same.
Does the background show with the old cartridge ?
If it does, its a drum unit problem, if not its a toner cartridge problem, and that should be under warranty if you've just replaced it.
Dec 06, 2008 | Dell 1700n Laser Printer
1700 printer
How did you install the printer?
I have found that if you just let your computer recognise new hardware, it really has a hard time with the USB printing to the 1700's.
Originally there was a disk that came with the 1700 printer. You do want to use that.
During the install, you run the software, and then turn on the printer. (You can have the printer on during the install, but ignore the Windows Wizards that come up).
If you don't have the original 1700 install disk, you can download it from Dell.
The problem is with USB port configuration. These little 1700's are just a pain sometimes if not installed the way they were originally designed.
Jul 31, 2008 | Dell 1700n Laser Printer
Mar 04, 2008 | Office Equipment & Supplies
Printing size and shifting to the right
Hi there check the print margins within MS Word goto
  1. File
  2. Page Setup
  3. Margins
And check that they are OK. if not check that you haven't got the wrong size paper set in word. Same as above but select Paper size then check in the printer driver that you have the correct paper size selected and that you haven't selected a strange margin.
Hope this works
Thanks J
Nov 28, 2007 | HP DeskJet 5650 InkJet Printer
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Dell 1700n Laser Printer Logo
209 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
