Question about Intel Computers & Internet
No responce lap motherboard is not power on wich component is foultey
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
If its not plugged in it could be your battery needs to be charged or replaced if it is plugged in you may need to replace you power cord/charger
Posted on Jan 29, 2009
How to connect the raidmax rx-730ss power supply to the gigabyte ga-z97x-gaming 3 (rev.1.0) motherboards 'ATX_12V_2X4' port?
The 2 plugs are seaparte because many mainboards do not have the 8-pin CPU power plug. Use the second 4-pin on the side of the connector.
Aug 02, 2014 | Gigabyte Computers & Internet
I have an HP dv6 1350us. I just replaced the brackets on the screen and put it back together. I then plugged in the ac cord to the dc jack and the light (on the right side next to the jack) comes on, but...
You may have helped with the last drop in the "chip creep" effect and broken the contact between the motherboard and the power regulating chip. This is a common problem on Toshiba and HP laptop motherboards, here's how to repair this Maxim 1987 power chip problem. This Maxim chip regulates the voltage for every component on the board, and if it gets desoldered in at least one spot, then the motherboard just won't work.
It's basically a design flaw and it's nobody's fault (OK, it's HP's fault), and I'm sure you can pull off the repair, just stick to the instructions.
If this post was helpful and informative, please vote with a Thumb Up. Thank you.
Jan 18, 2011 | HP Pavilion DV6500Z Notebook
I have a Dell inspirion 1525 which is less than 2 years old however it will not power up, there are no lights on the laptop and no power going in. The charger has a green light on when plugged in but...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 23, 2010 | Dell Inspiron 1525 Notebook
Motherboard power is on but cannot display screen, the monitor is black or no screen.
your problem could be almost any of your hardware components
the best way to detirmine wich one/how to fix it is with a process of illimination. You should do this by switching your hardware components with known good ones.
being a display problem the order i would test with is this.
  1. disconect everything but the screen
  2. swap screen for a known good one
  3. disconect graphics card and try the onboard (if no onboard try another gc)
  4. test psu (power supply unit) this can be done with either a psu tester, multimitre or try with another psu
  5. try removing all your RAM, when you boot if your system beeps a couple of times you know that your motherboardand cpu are good. if it doesnt beep it is probably your motherboard or cpu.
Oct 14, 2009 | ASUS P4P800-MX Motherboard
Lap top will not power on
There are a few things that can cause this. Start by removing the battery and starting on AC only. Then remove the memory and try each chip separately. If these aren't the problem, then I'm afraid the power management system or another component on the motherboard may have failed. You will need to take it in for a professional diagnostics.
Jul 27, 2008 | Dell Latitude D600 Notebook
ADSL modem hangs when booting!!!
It doesn't really sound more than it may be a bad phone line, I mean the actual wire. When you move it your connection changes. There isn't enough signal really to interfere with the motherboard on a EFI level.
May 03, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
CPU problem
that the problem maybe on your power supply adaptor,
if ur monitor appear blue screen maybe ur power supply component has problem
Apr 10, 2008 | ECS RS400-A (V1.0) Motherboard
Will not boot up
Disconnect all the disks and CD, remove memory and everything else including all the added card (Video, network,etc..).
Power up with processor only and if you don't hear any beep you have a bad motherboard or processor.
If you have any beep power off and add the memory and try again. Keep adding one component at the time until you discover wich one is creating an issue.
PS Did you verify compatibility between motherboard and processor?
Oct 19, 2007 | EliteGroup P4VMM2 Motherboard
Laptop motherboard repair components
The best way to find the part you need is search around for the board manufactures name. Then goto there web site. You may be able to download technical data right off the manufactures web site. Over heating is a big problem with lap tops. You never want to place your laptop on a soft surface when its on. A soft surface blocks the fan from extracting heat from your laptop , resulting in a over heat and eventually failure. You want to place your lap top on a hard surface when its on. This will provide ample room for your fans to cool your lap top efficiently. You can also purchase a laptop docking plate. It not only is a hard surface but also it has its own fan to increase the cooling capability of your laptop.
Sep 22, 2007 | Compaq Presario X6000 Notebook
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
