Question about Dell Inspiron 6000 Notebook
Diagnotics Alert ! on Dell Laptop w/ AT&T internet card
Diagnotics Alert ! Corruption has been detected in FeatureManagerSetting, back up file hes been loaded'' I get this error when I go to my internet service on my computer. Anybody know how to correct it?? Thanks
  • Dan rogers
    Dan rogers May 11, 2010
    does it stop you from being able to do anything on your computer?
  • 214 Answers
Sounds like your Dell Control Point Connection Manager is corrupt. If you reinstall this is should fix the problem.
Posted on Jan 29, 2009
  • dirinda89
    dirinda89 Jan 29, 2009
    Here's a little more info for you..
    The Dell ControlPoint (DCP) Connection Manager is part of a multipurpose utility called Dell ControlPoint, which includes a Security and System Manager. The connection Manager application enables you to easily set-up and automate their network connections and profiles from a single utility. The DCP Connection Manager replaces multiple utilities that were required in the past to configure network connections and settings. The connection manager helps manage the following connection types and settings:
    Wi-Fi
    Mobile Broadband
    Dial-Up
    Ethernet or Wired (Cable Broadband, DSL)
    Bluetooth or Ultra Wide Band (UWB)
    GPS
    Printer
    Internet Browser & Security
    Virtual Private Network (VPN)
    Share Folders
    Map Network Drives
    Dell Controlpoint Connection Manager comes preinstalled in Dell's new Latitudes and Precision portables,it can be reinstalled using Dell Resource CD or downloading each application on Dell Website.
    Dell Controlpoint Connection Manager is compatible with Windows XP or Vista but cannot be installed in previous Latitude series.
    Hope this helps you! Good luck.
7 beeps will not come on
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 13, 2012 | Dell Computers & Internet
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Alert! Chipset Heatsink not detected. System halted! is the alert that comes up when I turn my computer. What can I do?
Hi scotteg71121...
The alert is caused by a loose chipset heat sink.
Dell has a self test that prevents further damage by halting the system and displaying the message Alert! Chipset heat sink not detected. System Halted.
The solder joint seems to fail from constant tension and heat.
If you find the missing clip inside the computer you can solder it back in place and reattach the chipset heat sink wire hook.
If you can't find the clip you can replace it by bending a thin piece of wire in a half circle.
You can see a picture of where the clip goes on your computer motherboard by following the link below.
Please take time to rate me
http://www.aplusperfect.com/articles/chipset-heatsink-not-detected
Sep 05, 2011 | Dell Dimension 4600C PC Desktop
I left my Dell Inspiron on shut down overnight whilst it installed some windows updates. The next day it flashed up saying that the laptop hadnt shut down properly and needed rebooting and repairing. THis...
Boot up with the vista disk that came with your laptop and do system recovery again. Ignore the file corruption message because your going to be reversing your OS back in time to when your files weren't corrupted. Back it up to a time you know it works, the dates will be listed. Afterwards things should be fine, but know that vista does this alot for alot of people. NOTE: when you go back in time you will not have any files you had inbetween the date you back it up to and today. OTHER THOUGHTS: those mac commercials from way back when weren't just Evil Apple iPropaganda. Consider updating to Windows 7, I've never had a problem with it- where as your boot loop error happened to me on a weekly basis.
Mar 02, 2011 | Dell Inspiron 1525 Laptop Flamingo Pink
Why wont my inspiron dell laptop feed internet
check if ethernet card is detected in device manager or not if yes
update the drivers fro www.support.dell.com
if still dosent work try to use external ethernet card.
Apr 01, 2010 | Dell INSPIRON 6000 CENTRINO...
Dell latitude 110L laptop will no longer emit audio. It was working in the morning! all the media files are playing but I can't hear anything and the sound is at its max level. Please help
I found some conflicting info about your machine but it may have a Realtek audio card in it. Download this driver software and reinstall it to see if it solves your problem, if not post back here.
Feb 23, 2009 | Dell Latitude D600 Notebook
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Blue screen corruption error
i think ram problem or another one os install
mostly its ram problem
Oct 24, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Notebook Logo
532 people viewed this question
Alun Cox
