Question about Coby MP-C7085 MP3 Player
Will not let me synch music files.
I had to reset it to get it to unfreeze. It will not let me sync files off of windows media player.
    President:
  • 563 Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
You don't need to use Windows Media Player in order to put music on your player. There are various reasons why it may not be syncing. Below are instructions for how to put music on the player using copy and paste. It's the easiest way to add music to an MP3 player.
How to load an MP3 player without using Windows Media Player. First, allow me to clarify a few things so that there is less confusion: When you connect an mp3 player to a computer, you will not be able to use it until it's disconnected. In other words, the only thing you should do while the player is plugged into the computer is adding or deleting files. You can't use the buttons on the player while it's communicating with the computer, and as long as it's connected to the USB port, it's communicating. Ok, let's get started! Step 1 Connect the player to your USB port using the cable that came with it. (NOTE): If the player has a male USB connector already on it, connect the player directly into the computer without using the cable. In other words, only use a cable if you have to. Step 2 Click the "Start" button or press the key on the keyboard that has the Windows logo, and go to My Computer (Windows XP) or Computer (Vista). Step 3 Locate your MP3 player on this screen. Do not close this window; just minimize it. (NOTE): It should show up under Devices with Removable Storage or as a device under "Other." Most importantly, it should show up on this screen as something! When the player is connected, you should have something on this screen (usually an icon of some sort) that represents the player. This lets you know that the unit is ready to receive files because it's being recognized by your computer. Step 4 Locate and open the folder that contains your music files. Step 5 Using the mouse, copy one or more files. (Right mouse click on file, then left mouse click on copy) Step 6 Go back to the "My Computer" or "Computer" screen, right mouse click on the icon representing the player and left mouse click on paste. You should see a small status bar appear showing the file(s) being copied from your music folder to the player. Step 7 Click on the Safe to Remove icon found in your system tray and disconnect the player. And that's it! If you need additional assistance, I will help in any way that I can.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
How can I stop my music from being deleted when I plug my player up to the computer to sync more music onto it from windows media player?
If on iTunes it will only allow music that you have purchased from iTunes. Anything else it sees are pirated. You can get over this by buying an iTunes Match subscription. This allows you to transfer any music it iCloud and iTunes, so when you synch, all your music is there. You can drag your music from Windows Media player to iTunes.
If you are using a Windows phone, just Google the problem as someone will have come across it before.
Rather than Synching, you may be able to drag individual tracks to the player. Synching does what it says, it make the one device the same as the other device, so if there are tracks on the player that are in Windows Media Player, it will remove them so both are the same. There may be a setting to NOT Delete what is on the player, just Update New Tracks.
Jul 19, 2016 | Audio Players & Recorders
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
My refurbished sony walkman 16GB media player worked fine for a couple weeks but now when i try to sync music from windows media player to it the player freezes and i have to press the reset button on the...
don't use windows media player if it freezes, try winamp free at winamp.com it whats i use for most of my devices as well as what i use to maintain my music library
Feb 16, 2011 | Audio Players & Recorders
I recently bought a IQ Sound SC-4528HB 4GB mp3 player. Windows media player shows synched music however when mp3 is not connected to pc I recieve "NAND No Files!" When I check to see if files...
the way i figured it out is that you cant use windows media player to sync the music you have to drag and drop thr files from their folders into the removeable disc drive because im guessin the whole file folder thing is to complex for it lol so try to drag and drop there is no folders and it should work. let me kno if it works for you email me at paulpenn91@yahoo.com
Dec 29, 2010 | Bell Technology IQ Sound SC-2528 MP3...
Synch not possible
I would recommend using a different program to sync your music to your MP3 player:
http://www.mediamonkey.com
Jan 28, 2010 | Nextar MA933A MP3 Player
Sansa e200 Fragmented File Issues
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jul 03, 2008 | SanDisk Sansa e200 MP3 Player
Having difficulty sycing music files to my mp3
If you try to sync too many songs at once, you will overload the player - don't sync more than 10 at a time. Reset your player, and take notice of the last song that was synched - because that particular file may be corrupt.
Jun 25, 2008 | RCA Audio Players & Recorders
"Synch problem: Synchronise to continue your music subscription"
I would suggest formatting the unit and trying again, but this time do not sync it with media player. Plug it into your USB and got "My Computer", the player will show up as a removable disc usually drive f:, right click on the drive and hit format, quick format shoudl work. Once formated double click the removable disc drive, and then click and drag or copy and paste your music into this drive and see what happens. That player should support WMA files, but just to let you know, if you convert those files to MP3 it will take about half the space and therefot you can store more music at once. L8R Hope this helps and good luck
Sep 16, 2007 | SanDisk Sansa E280 MP3 Player
Sansa MP3 M240 No volume when playing songs, says to synch
Where did you download the songs? Napster?Rhapsody? Any online music stores? Try synchronizing them using their software. If you have ripped songs from a cd you may want to rip them again and before ripping them check this option on your windows media player software. Tools > Options then under RIP MUSIC remove the check mark that say's Copy Protect Music or choose the file format as MP3. Then format the device using the windows media player software(for version 10 = click on the sync tab then choose the pencil like icon on the far right, for version 11 = right click on the sync tab choose the player and choose format) use after doing that rerip the songs using the windows media player software.
Jul 14, 2007 | SanDisk Sansa m240 MP3 Player
Sync with windows media player
I have the same issue where my pc won't recognise my mp3, or only occassionally does, and then locks up. The problem with media player is it eats up so much memory while trying to synch files / delete / add etc and brings your pc to a grinding halt. So the solution I'm told is the MS Synch Tool, download off MS site and use it rather than the player to switch your files. I'm trying it now.
Dec 09, 2006 | Samsung Yepp YP-Z5QB MP3 Player
Coby MP-C7085 MP3 Player Logo
43 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
