Question about Brother HL 5250DN Laser Printer
"Drum" light is on.
My "drum" indicator light is on and I can print anything. I have a brother HL 5140.
Thanks for any help,
Jane
    New Friend:
  • 114 Answers
THAT MEANS YOUR DRAM LIFE IS END. YOU NEED TO CHANGE YOUR DRAM.
Posted on Jan 29, 2009
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
Put a new drum in my hl-5140 two weeks ago, now the drum light is flashing again and nothing will print.
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
This should reset the DRUM counter.
Apr 14, 2010 | Brother HL 5140 Laser Printer
Brother hl 5140 drum light comes on then off every 4
With the front cover open, press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the go button, then close the front cover.
This will reset the drum counter.
Mar 27, 2010 | Brother HL 5140 Laser Printer
The drum indicator light is on. Is this a repair
the drum is the tray that holds the toner, it comes out when you remove the toner. you can buy this part at any store that sells the toners. it is normally more expensive than the toner but will last you about 4 of them
Mar 22, 2010 | Brother HL 5140 Laser Printer
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
I have a brother HL-5140 which has some nasty ink spodges on each page. Have carefully cleaned wire as recommended . Is there anything else I can do?
if they are evenly spaced, it will be 1 of 2 things, either the fuser or the drum, if you want to check the drum, take it out, take the toner out of the drum, and rotate the drum by turning the gear, be careful not to touch the drum not have it in direct sunlight or incandescent light and see if you can find the spodges on it.
you can also do a test print, print from the manual tray, and open the main cover after the paper goes in almost all the way. open the door, take the drum out and look at the paper, take it out slowly in the direction the paper was going and see if you see the splodge, if you do, again you will know its the drum.
thanks adi
Jun 27, 2009 | Brother HL 5140 Laser Printer
How long will the drum last on a Brother HL 5140 when the yellow drum light starts flashing
I have reused the drum for three life cycles and the print quality is still good. Just reset the counter until the print quality suffers because the cost of the drum exceeds the price of a new printer. According to Brother to reset the counter
Apr 10, 2009 | Brother HL 5140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5250DN Laser Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
