Question about Epson Stylus 2200 InkJet Photo Printer
Vertical bars through printout
Please Help. I have an Epson 2200 which has been working fine till now. I am printing a series of photos on 6"x4" Epson Durabrite Photo paper. The first three printed fine and then I started getting vertical bars through the rest of them. I ran all the utilities - nozzle check, print head alignment, and head cleaning. All the test pages generated also have the vertical bars running through them, but all three things check out ok. Thank you so much.
  • Pritika Chowdhry Jul 28, 2007
    Hello Inky, thank you so much for your detailed solution. As it turned out, I shut down and restarted the computer and printer the and since then it has been printing fine. Go figure!
  • Epson Master
  • 705 Answers
Look closely at the marks on the print, and in particular the distance between the lines. Now look into the printer through the paper exit path. Take note of the metal star wheels. Does the distance between the lines match that of the distance between the star wheels? If so then the plate that the start wheels are mounted into may have dropped. You can remedy this by gently lifting the plate back up by hand. Set the machine as if you where going to print a CD and simply lift the start wheel plate at each end. Do not force it or apply too much pressure. Ease it up and then try it again. If it needs more adjustment repeat and check again. If the marks appear to be caused bu ink on one set of rollers or another, pass a really thick piece of card (like off the back of an A4 refill pad) through the paper path. Spray the rollers with a cleaning solution or windowlene (windex) and then pass the card through. This will help to clean off any ink. Again you can repeat this process as neccessary. Let us know if this helps before rating - if it does not I may have more info
Posted on Jul 27, 2007
  • Inky Fingers
    Inky Fingers Jul 27, 2007
    Plate to ease up
Epson 2200 won't print magenta
Clogged printer head. Cleaning cycle needed
Apr 02, 2014 | Epson Stylus 2200 InkJet Photo Printer
Hi when i print lines appear in my printout - i have ran the maintenance checks and nozzle check utility seems fine although the black looks a bit fuzzy - do you know how to resolve this problem please?...
If you haven't done so, run the alignment setup again. If that doesn't work, put in new cartridges and see if there are still lines in your printout. This will check if it's a printer issue or cartridge issue. Here's a PDF from epson on how to run the alignment setup. See page 11. http://files.support.epson.com/pdf/r300__/r300__pg.pdf
Mar 01, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
Colours not printing correctly
please check the charging roller of your new cartridge
Sep 07, 2007 | Epson AcuLaser C900 Printer
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
