Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Warm hinged seal on Jenn-Air french door refrigerator
    President:
  • 1,314 Answers
There is a heater runs through there that keeps the seals dry so they dont mold from condensation from opening the doors its called a mullon heater
Posted on Jan 29, 2009
LG french door refrigerator does not keep food cold. Left door pops doesn't stay tightly closed.
What do you mean by "pops"? If your problem is the door, then it is possibly leaking out your cold air. It could be the seal or the hinge.
Aug 11, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
Top door not aligned with bottom
The parts diagram link that I am sending shows the hinges. You can adjust them. http://www.appliancepartspros.com/left-refrigerator-door-parts-for-jenn-air-jfc2089htb.html Loosen the screws and shut the door and then tighten them
Apr 07, 2014 | Jenn-Air JFC2089HTB French Door...
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Frost build up Jenn-Air JFC2089HTW
have you tried to re align the hinges? is the hinges broke?
Jun 25, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
196 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
