Question about HP Pavilion dv2000t Notebook
Wireless wont work
It would go in and out as the computer would heat up always said had good signal but no access
  • 218 Answers
Read this article and see if it applies to your situation. If so, call the special HP number and see if they'll fix your computer under the special enhanced warranty program. Others have had good luck with this.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Jan 31, 2009
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
Hi i have realtek RTL 8187 wireless adapter, and when i watch in my antenna managing program, connection is quality and signal streght about 80% THATS GOOD. always was good connection, but now yellow and...
somebody is accessing your wireless network and getting free internet service from you unless you had setup a wep security! if you have an un-secure network then anybody with a wireless adapter can access your network and access your internet free and drag down the speed of your internet connection.
however, if you do have wep enabled and there is more than one computer connecting then this will slow your connection down as well. please remember that there are some games and gaming sites that are bandwidth hogs and will slow down other computers connection on the same network. also watching streaming videos and gaming at same time can slow down connections as well.
Aug 25, 2011 | Toshiba Realtek RTL8187B Wireless...
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
DI-624 always lost connection after use about 10mins. to 20 minutes
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
Nov 16, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Wireless connection will not work
The computer is viewing the signal, but its not connected yet. For that you have to enter a "key" in hexadecimal format. In other words you have to configure the security of the wireless connection on the router, then you have to enter the "key"that the router gives you. To enter the administrative configuration of the router, connect with the cable the computer and in the internet browser, enter 192.168.0.1 or search for gateway IP address of the computer. There you configure Wireless Settings. Always use encryption for security reasons. WEP encryption will be good.
Jul 01, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Wireless connection
Sometimes the wireless card will pick up any signal it finds, like your neighbors..go into control panel and network connections and take a look if there are other signals being picked up. If so there will be more than one connection showing. Click on your connection and that should set it to automatically always connect to yours and not someone else's...if the wirelss card was not functioning then you would not get any signal at all...finally try starting your laptop next to your router and see if that works better, there may be some interference in the house not allowing you to get a strong signal..good luck. Please rate this solution.
Mar 08, 2009 | Acer Aspire 5610-4648 Notebook
No internet connection
tobe honest try to uninstall internet explorer 7
Dec 09, 2007 | Belkin Wireless Cable/DSL Gateway Router
Strong signal but no connectivity
ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Oct 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
HP Pavilion dv2000t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
