Question about Toshiba Satellite L10 Notebook
TOSHIBA STELLITE L10 SERIES
I HAVE TWO MESSAGE ERRORS. A PROBLEM HAS BEEN DETECTED AND WINDOWS ( XP ) HAVE BEEN SHUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER. I DO PLAY A LOT OF GAMES ON POGO FOR LONG HOURS.THE PC GETS TOO HOT AND WAS SHUT DOWN. PC IS 2 YRS OLD HAS JUST STARTED THIS PROBLEM THE OTHER DAY. JUST DID THE ONE TIME I HAVE NOT BEEN PLAYING GAMES AS MUCH AND SHUT DOWN THE COMPUTER IF I FEEL ITS TOO HOT. THE BATTERY IS IN THE PC. SHOULD I REMOVE IT AND SEE IF THE PC WILL STILL RUN HOT. THE BATTERY IS NOT ONE OF THE ONES THAT WAS A RECALL. I AM HOOKED UP TO THE AC POWER LINE. THE OTHER ERROR MESSAGE IS VIRTUAL MEMORY IS LOW.. AND WINDOWS ADDS MORE IS ADDED. WHAT SHOULD I DO ABOUT THAT. THE PC DOES RUN OK.I DO A DISK CLEAN UP EVERYDAY .ALSO A DEFRAGMENT EVERY WEEK.. WHAT DO YOU THINK ABOUT THE REGCURE FOR THE COMPUTER TO CLEAN IT UP. ALSO HAVE A PRINTER HP 1610 AND A SMALL SET OF SPEAKERS HOOKED UP TO PC. USING A EXTRA UBS PORT TO RUN THEM. PROCESSOR IS 1.30 GHZ ,496 MB OF RAM ADDED RAM IS WHY ITS 496..INTEL (R) CELERON (R)M -SERVICE PK 2- VERSION 2002 WINDOWS XP THANK YOU FOR ANY SOLUTION
  • Anonymous Apr 18, 2008
    yes
    President:
  • 2,961 Answers
First you would expect a notebook pc to run hot so don't worry too much, as long as you here the fan cutting in, but try to keep as well ventillated as possible and hoover around the vents in case of blockages. The shutdown may have also have been caused by a corrupt driver. Secondly the virtual memory is what windows uses to start up applications quicker when you use the same ones regularly, so this means that the memory you have fitted is low, as your graphics will take the memory usage up depending on the type of graphical hungry games you run, as well as applications, so i would suggest fitting another memory stick, as you probably have 512MB fitted, so fit another 512MB stick to take it to 1GB of memory. As for cleaning up temp files and obsolete registry files, i would recommend Ccleaner, it's free and free of any spyware. You can download it here:- http://www.filehippo.com/download_ccleaner/
Posted on Jul 27, 2007
SOURCE:
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
I have an Window XP 2002 operating system that is shutting down.
this has to be caused mainly due to some hardware problems or hard disk problems. try removing your bus wire the white belt you have connected with your hard disk and reconnect it again . if it doesnt work try replacing a ram for temporary to chech the problem whether its caused by ram. let me know if the problem persists.. thank u :)
Jul 13, 2010 | Microsoft Windows XP Home Edition
My computer is stuck in a roboot loop. i have windows xp OS. it suddenly shutted down n when i start my computer now, it shows me a blue screen with message that a problem has been detected and windows has...
a_mamatha
If you can reply back with the error message as well this will better help me see what is going on with your computer. If you look at the link below it will show you the info that I looking for.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
Apr 14, 2010 | Dell Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
I keep getting the "a problem has been detected and windows has shut down to prevent damage to your computer" message. i've formatted and reformatted the HD and tried putting on XP. same message comes up....
its not a hard drive disk problem its your memory module, change your memory module inside the CPU a new one, or test another memory module to necessay detected the problem inside....
Jul 10, 2009 | Office Equipment & Supplies
this error comes from hardware .restart the system and press F8 key in start then choose safemode option and log on the system.then remove the software which you install on the system before error.try it it solve this problem......rate it
Apr 16, 2009 | Computers & Internet
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Blue screen of death
you need to boot from the cd, you have to change the boot senquence to start wth cd rom, when it prompts you to press any key to boot form cd,do that, it will load some files then restart again and the same message will appear, this time don't press any key, just let it continue on its own.
Mar 13, 2008 | Toshiba Satellite P25-S507 Notebook
I cannot reformat my pc windows xp,there's an error
If you are getting an error during installation its not good :(
Its prob either yor ram or hard drive faulty. Download memtest and test ram 1st as thats the most likely cause. Check that optimised defaults are loaded in bios also.
Jan 26, 2008 | Microsoft Windows XP Professional With...
Error screen
what was the last thing you installed? or pluged into the computer?
when windows starts to boot press f8 to go into safe mode and see if you can remove the last thing you installed.
Jan 08, 2008 | Toshiba Satellite A105-s4184 Notebook
Toshiba Satellite L10 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
