Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Washing Machine WT741
Flashing F - 12
  • Hotpoint Master
  • 3,463 Answers
Error code F12 is indicating a communications error between cards, this can be caused by one of several things..
A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is a electrical problem as opposed to a mechanical one.
If you cannot eliminate the problem your self, then i'm afraid your only other option would be to call an engineer out, it can be a difficult problem to pinpoint correctly.
Please leave a rating for my suggested solution.
Thankyou.
Posted on Jan 30, 2009
My door is shut and light is on flashing door on my hotpoint washing machine WT741. the door is shut and it does lock aswel so why the flashing light and no washing being done?
There is likely to be a problem with the 'door closed' sensor/microswitch requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 07, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima WT741 washing machine not working flashing F-03
F03 - Wash thermistor open/short circuit need a engineer out to fix it. hope this helps.
Mar 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washing machine wt741 wont stop flashing
Hi Donna, did you fix this? Am guessing you have by now one way or another but have posted a suggested solution for someone else: http://www.fixya.com/support/t3268817-hotpoint_wt741_when_power_button. Worked for myself and one other poster on here.
Jun 23, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
289 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
