Question about Dryers
Dryer thumping acts like the load is not balanced. Makes a thumping sound and the machine shakes wthin a minute of putting clothes in. This just began with the current load. I removed all clothes and tried the dryer w/o clothes and it did the same thing. Do I need to call a repair man or just bite the bullet and purchase a new dryer. Our dryer is 6 years old but has had quite a lot of useage as we have a large family. It is a GE. Thank you!!
  • 370 Answers
It sounds like the rollers have gone bad. Its an easy fix. If you like the dryer a repair man can fix it cheaper than buying a new one. you may even be able to fix it. if you go and go to the parts section and put in your model number you can pull up a diagram to see how to take the dryer apart. you can also order the parts from there too. Good Luck.
Posted on Jan 29, 2009
LG front load washer makes thumping sound in spin cycle. It sounds like fun rubs when machine is filling . It is not off balance.
Check the machine legs and ground level properly, and also dont put a single blanket or a single weight cloth sure it will make noise..
Feb 06, 2018 | LG Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Drum knock when spin cycle
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
While drying the drum makes suddenly a big noise and shakes a lot
Distribute the load of clothes when you put it in. Make sure they are balanced properly. If it's thumping during the spin cycle, stop it, open it up, move some clothes from the fuller side to the less full side, and see if that helps. Replace the springs inside the machine which suspend the washing drum. Open it up, take a look of it. Perhaps they're all saggy and this is permitting excessive vibration.
Put something under the machine to stop it from transmitting the vibrations to the floor of the house. An old sock folded several times and placed under each of the four feet may help. Rubber or foam will also work. Also, make certain the machine is level from front to back and side to side. Most washing machines have a large weight attached to the drum, usually a concrete block. It's supposed to prevent too much vibration. Check that one or more of the bolts holding it on haven't come loose.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Feb 02, 2011 | Miele Novotronic Premier 500 Front Load...
Clothes dryer makes a ''thumping'' sound
One of your rollers has a flat spot in it or something stuck to it. Every time it rolls round to that spot the drum jumps over the little speed bump in the road. The wheel needs to be replaced.
Mar 11, 2010 | Whirlpool GEW9200L Electric Dryer
Machine makes a thumping noise when spinning
If its thumping you have the maching overloaded and the clothes (very easy to do with heavy jeans or sweaters) are all on one side causing an out of balance situation. Try relocating some of the clothes to the other side of the unit and if that doesn't seem to help remove some of the clothes to eas the load on the machine otherwise it will never reach maximum spin speeds needed to rinse your clothes.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Washer thumps and stops right after moving wet cloths. Balance?
your timer has blown or it is your motor tacho . quickest solution is 2 fit another motor that is cheaper 2 get than a timer u should pay no more than £50, 4 a secondhand motor if u cant get 1 i have got some give me a line and u can buy 1 from me with 3mths guarantee good luck i have also got timers if u need that 2
Sep 04, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Dryers Logo
147 people viewed this question
Top Dryers Experts
