Question about HP Officejet 5610 All-In-One InkJet Printer
Need steps to scan document to email
Have 08 hp copier fax and scanner
  • 214 Answers
The destination of a scanned item can be set to E-mail using the Director screen. Before changing the scan to destination to E-mail, make sure the E-mail program is compatible by checking the following points:
  • The E-mail program must be set up and functioning properly. The E-mail program must be MAPI compliant.
After making sure the E-mail program is compatible, change the scan to destination to E-mail using these steps:
  1. Open the Director window.
Click Settings , and then click E-mail Settings .
This will let you enter info so your printer can find your email program. Also, if you click, Help, Onscreen users guide from the director window. These are usually pretty good with step by step directions. Hope this helps! Happy scanning!
Posted on Jan 29, 2009
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
Tip
How to Scan in Windows 7 without Using HP Software
Introduction
Windows7 provides a basic set of scanning drivers, also referred to asWindows Image Aquisition (WIA) drivers, that you can use as analternative to scan a document when you cannot scan using the HPdrivers. You might choose to use these scanning drivers for one of thefollowing reasons:
  • Your product released before Windows7 and HP has not released drivers that support scanning for your product.
  • You have not installed the available HP software that includes scanning.
  • You are troubleshooting a scanning problem and trying to identify the source of the problem.
Method one: Scanning with Windows Live Photo Gallery
To scan a document using Windows Live Photo Gallery in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, and then click Windows Live Photo Gallery.
  2. Click File, and then click Import From Camera or Scanner.
  3. Click the product you are using to scan, and then click Import.
  4. Make any desired setting changes, and then click Scan.
Method two: Scanning with Paint
To scan a document using Paint in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, click Accessories, and then click Paint.
  2. Click the Paint button (c01886001.gif), and then click From Camera or Scanner.
  3. Make any desired setting changes, and then click Scan.
Method three: Scanning with Windows Fax and Scan
To scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif, click All Programs, and then click Windows Fax and Scan.
  2. Click New Scan.
on Jan 19, 2010 | Office Equipment & Supplies
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
How does the 1210 scanner work with Windows 7? I have downloaded the driver for the printer and it works ok, but I cannot use the software for the printer. The copier and the scanner work, but i cannot...
You will have to do a two step process to send a scanned document or image by email; the scan to e-mail button won't work. Scan using either Windows Fax and Scan or Paint. Save your file. Then start (Compose/Write) an e-mail to the person you need to send the document. Click Attach and browse to the location where the scan was saved. The default folder is C:/Users/<user_name>/My Documents/Scanned Documents . Click OK after selecting that image. Finish writing your e-mail and send it.
If you'd like to automatically open the e-mail program, browse to the folder where you saved the fax from Computer (Start button) and right click on the image. Choose Send to Mail Recipient. The new mail compose window should open.
I hope this helps.
(a program like PaperPort may let you send to e-mail recipient without the extra step; however I'm not sure of the details.)
Mar 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
Is there a fix for being able to scan hpj3680
Hi Melinda,
Windows7 provides a basic set of scanning drivers, also referred to as Windows Image Aquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers. You might choose to use these scanning drivers for one of the following reasons:
ScanningUse one of the following three methods to scan a document. Method one: Scanning with Windows Live Photo GalleryTo scan a document using Windows Live Photo Gallery in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , and then click Windows Live Photo Gallery .
  2. Click File , and then click Import From Camera or Scanner .
  3. Click the product you are using to scan, and then click Import .
  4. Make any desired setting changes, and then click Scan .
Method two: Scanning with PaintTo scan a document using Paint in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , click Accessories , and then click Paint .
  2. Click the Paint button (c01886001.gif ), and then click From Camera or Scanner .
  3. Make any desired setting changes, and then click Scan .
Method three: Scanning with Windows Fax and ScanTo scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon c01319360.gif , click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
Please reply if the problem persists.
Regards,
Rizwan
Jan 19, 2010 | HP J3680 Officejet All In One Printer
Hp scanjet G2410 not sending email documents to outlook express
scan using Scanner and Camera Wizard
1.From "My Computer" right click the appropriate Brother FAX, MFC or DCP machine.
2.Select Get picture using Scanner Wizard.
3.Click "Next" at the welcome screen.
4.Select the save options that you require and click "Next".
5.The Wizard will now start to scan using the settings you specified.
6. Select the "Nothing. I'm finished working with these pictures" and click "Next".
The images will then be saved to the the location that you specified in step 4.
later you can attach the scanned file to your outlook express.
Sep 03, 2009 | HP Scanjet 4470c Flatbed Scanner
Scanner not working. HP deskjet f4185.
Aug 26, 2009 | Office Equipment & Supplies
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Scan to pc
On my version of the hp software I can quite easily do this.
You will need working email software on your pc, so to scan the image, ensure that the pc is connected to the scanner and the pc is switched on - with all the HP scanning software installed.
Press the scan button on top of the scanner, with the document inside the scanner faced down.
When the HP Software pops up on the PC - the scanned image should appear. You can then click the email as attachment button in the HP software.
There are many ways to do this operation. So if you get stuck then let me know I we can go into more detail.
Please don't forget to rate.
Jul 04, 2008 | HP PhotoSmart C4180 All-in-One Color...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
