To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
Its possible (but not likely) that when you took it into a warm room condensation built up inside it. Try removing the battery, memory cards and letting it sit in a warm, dry environment for a few days and try again.
If nothing changes I suspect that a component has failed, but -6F is still within the operational range of commercial electronics. If your device is still in warranty then I would call HP up and ask for a warranty replacement. Let us know if you have any other questions and please don't forget to rate this posting.
