Question about RCA 25110RE3 Phone
My durabrand model PH-3238 telephone suddenly stopped working. I can hear a dial tone but none of the keys work and the display lights is not on. I changed batteries but this did not help. Any Ideas?
5 Suggested Answers
SOURCE: Setting time on Durabrand Phone Model # PH-3238
Hold Delete Button and press Down Button! then press delete button that you can change anything!
Posted on Nov 02, 2008
SOURCE: durabrand ph 3238 how do i change date
I use it with voip (computer) and it updated by itself.
Posted on Jun 11, 2009
SOURCE: need manual for Durabrand model # telephone 3238
how to initalize a previous extension that has been out of service and we do not know what happened
Posted on Oct 12, 2009
SOURCE: WHERE CAN I GET A MANUEL FOR MY DURABRAND PHONE
how do I store a number in a Durabrand corded phone - model Ph 323 13 memory speaker phone
Posted on Oct 20, 2009
VanDaniel
SOURCE: durabrand phone model ph-3238
While holding down ‘Delete’, tap the ‘Down’ button. You will then be able to use ‘Up ‘ and ‘Down’ to set contrast, language, area code, time, and then date. Tap ‘Delete’ once your selection has been made on each item to move forward to the next.
Hope this helps you and any others as I had the same problem, and it took forever to figure it out.
Posted on Dec 29, 2009
My Durabrand desk phone suddenly stop dialing, I can hear dial tone clearly, but cannot dial on keypad nor is the display active. any ideas??
If you have a bracket that uplifts the phone, remove it using the clips. After you do this, you will see a battery door. This may not solve your problem, but for me, changing the batteries fixed the problems.
Oct 16, 2009 | Lands Phones
WHERE CAN I GET A MANUEL FOR MY DURABRAND PHONE MODEL PH-3238
Oct 13, 2009 | Lands Phones
"line out" not working
check program to see if key is still programmed.next make sure you have dial tone on all your lines
Oct 06, 2009 | Avaya Merlin Magix Telephones: 4406D+...
Durabrand phone model ph-3238
May 02, 2009 | Lands Phones
Buttons won't work
Try taking a credit card or ID card and placing it on its side across the top of the keys. Then swipe it down across the keys. This should unstick any of the keys that may be stuck and your phone should start working fine.
Jan 14, 2009 | Nortel Meridian 9417CW 2 Line phone
Aug 20, 2008 | Lands Phones
Durabrand phone model 5562 .
press and hold the delete button and press the up and down button to set lcd contrast, language, home area code, set time/date.
Feb 27, 2008 | Lands Phones
RCA 25110RE3 Phone Logo
158 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
