Question about Acer Aspire 3100-1405 Notebook
Pop up for edata security error
Keep getting pop up - already remvd but how do I re-install This thing pops up about 8 different times about 4 times a day.
Security warning keeps popping
To suggest a workable solution, we request you to furnish some more details on your issue like:
1) What is the exact security warning you are getting?
2) Do you get it only when using internet? Or it pops up even when not using internet?
3) Does it pop-up only when running a specific application/ website?
4) Is the security warning popped up by your security software (if any)? Or you are getting it through Windows itself?
5) Which version of Windows are you using?
In the meanwhile, we request you to scan your system thoroughly (if you have not done this already) to detect and get rid of infections (if any). Also, if you are getting the warning while running any third-party application, you can check if the application is compatible with your Windows version and then, try uninstalling and reinstalling it (if it is compatible). To check compatibility of the application, you can refer to its user guide/ installation guidelines.
GuruAid.com
Jun 23, 2014 | Computers & Internet
Compatibility problem?
What does it say ?
are you on the internet when it pops up ?
Internet pop-ups can be an annoyance.
These windows are usually associated with different forms of advertisements and at times can include viruses that can infect the computer.
Pop-ups do not have to be a part of computer use if the user does not desire this distraction. There are ways to stop pop-ups and prevent them from appearing unless desired.
Pop-up blocker allows the user to block these items and select which items to allow. Open Internet Explorer.
Click "Tools" from the menu bar. Tools can be found on the bar that lists "File, Edit, View, Favorites, Tools, Help" directly beneath the address bar.
Click "Internet Options" from the "Tools" menu.
Click the "Privacy" tab in the "Internet Options" box.
Click to check the box that says "Turn on pop-up blocker" in the "Pop-up Blocker" section of the menu.
Click "Apply" to save changes.
Click "OK" to close the "Internet Options" box.
The computer will now block all pop-ups from websites.
If downloading items from the Web, the computer will ask whether you would like to allow these items to be opened.
IE: 8 right click in the top toolbar select the command bar this will add it to the toolbar then on the far right hand side select the tools then from the drop down list pop up blocker make sure its turned on and settings
hope this helps
It's easy to learn how to stop pop ups, and you don't need to download pop up blocking software to get rid of those annoying ads. Just try these easy fixes before downloading a pop up blocker.
The first three methods assume you can use the software you already have. It's quick and simple, and you won't need any add-ons with these methods.
It takes only a few minutes to stop pop ups yourself, even if you are not technically oriented. If Internet Explorer 7 (IE7) or Mozilla Firefox on a Windows Vista computer but these steps should work for any Windows compatible computer (although it may vary some if you have a different version of IE).
Here are four easy and quick ways to stop pop ups on your computer. You can use any one (or more) of these methods to get rid of those pesky pop up ads within minutes.
How to Stop Pop Ups - Method #1: Use Your Settings on Internet Explorer 7
Step 1: On Internet Explorer 7, go to "Tools", then "Internet Options"
Step 2: Click on the "Privacy" tab
Step 3: On the bottom, under "Pop-up Blocker", click the checkbox to "Turn on Pop-up Blocker". Click "Ok".
How to Stop Pop Ups - Method #2: Use a Different Internet Browser (Firefox)
Try using Mozilla Firefox instead of IE because Firefox automatically blocks pop up windows (unlike Explorer). You can download Firefox at http://mozilla.current-version.com.
How to Stop Pop Ups - Method #3: Use Your Web Toolbar
You may already have the google or MSN toolbar installed on your browser. If you try this approach, you may also want to read my articles on how to stop pop ups with your Google toolbar and MSN toolbar.
How to Stop Pop Ups - Method #4: Download a Paid or Free Pop Up Blocker
If you've tried the above steps, and you're still having issues, then you should consider downloading a pop up blocker program.
Two reliable free pop up blockers include the Google toolbar and MSN toolbar. Another popular paid pop up blocker is at http://ivyliu.com/panicware.htm.
For everyday pop up blockers, the above methods should work. However, if you've tried all of these suggestions and you're still having problems with persistent pop-ups, then it's likely that you have been infected with spyware.
Summary of How to Stop Pop Ups
First, try changing your IE browser settings to block pop ups. If you have Google toolbar or MSN toolbar installed, then you already have a pop up blocker installed along with it. Try using the toolbars, or try switching to the Firefox browser.
Finally, you can also download a pop up blocker (free or paid). It's easy to stop pop ups without having to download pop up blockers.
If these steps do not remove your pop ups, then you may want to download a free or paid pop up blocker.
If that fails, then you probably are infected with spyware, which must be removed in order to get rid of ad pop ups.
But the above four methods should work to stop most pop up windows.
Apr 22, 2013 | Acer Aspire Computers & Internet
When playing games in facebook I cannot send and recieve gifts and keep getting things blocked, why does this always pop up at top of games ?
You need to adjust your pop up blocker to allow pop ups for Facebook. Typically IE8 gives you a message at the top of the screen when a pop up is blocked with the option to allow pop ups from this site either for this one session or forever. if you do not see this you can adjust your settings by clicking "Tools->Pop up blocker->Pop up blocker settings."
You may also need to adjust the security settings for Facebook from "Tools->Internet Options->Privacy." Make sure you adjust privacy settings for facebook only!!
Apr 14, 2012 | Microsoft Internet Explorer 8
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
Pop ups asking for email passwords in Outlook 2003
It's like they told you, its a Microsoft issue, sort of.
The application has a corrupt registry key, reinstalling the application, the MS outlook 2003 will 'magically' fix the problem.
The only other thing that makes that window pop up, besides the obvious, which is you reset your password, is when you are trying to cross a domain. And if you asking in your head, what is that, then you probably not doing it. It doesnt happen by accident.
Just re-install the software, takes 5 minutes, and brings years of relief...hehe
oh, to test my theory, set up outlook express with the same settings you have in your outlook 2003. You probalby have outlook express already installed on your computer, just click on start, all programs, outlook express, if you dont see it, its a free download,
just go to google.com and type in download outlook express and install it, then open it, click on tools up at the top, then accts, then mail tab, then add
type in the info its asking for , like your pop servers name, and the smtp server
the default ports are 110 for incoming, and 25 for outgoing
spin
May 01, 2009 | Microsoft Windows XP Professional
Acer eData Security Management
delete/uninstall edata security completely.
Then download a more stable security like AVG, McAfee or Norton, check this site some are having the same problem and this seems to be the best solution.
Apr 09, 2009 | Acer Aspire 9300-5349 Notebook
Pop-up acer edata security management each time open laptop
I would go to the program file itself (it might be on the desktop, might be in the start menu, or might be in a folder in C:\Program Files) open up the acer e-manager and look for an option for settings.  You should be able to un-select options for security notifications and automatic updates.  I do not have the program on this computer, but I have seen it before on other laptops.  Most all programs like that will let you change the settings.  The security updates are not entirely necessary, so long as you have an anti-virus program installed on your computer.  So just turn off the auto-updates and the notifications through the program itself.
Mar 26, 2009 | Acer Aspire One PC Notebook
My acer aspire 3105WLMi windows Vista Basic keyboard keeps missing random letters as i type..even now! my laptop is 6 months old and constantly runs via the plug into the wall which then runs to the...
First Things first. Un-install the software that you installed immediately as while you are Internet Banking a pop-up is a security threat and It is not a security pop up mind it.
Regarding the keyboard missing the letters. Please follow the following :
In control Panel go to Keyboard settings and move the repeat delay & repeat rate to a slower setting.
2nd Option
open a Word processor and type in ABC to Z & All the combinations of the same & special characters using shift. Repeat this 2-3 times. If same letters are missing it means that the keyboard has a problem and needs disassembly & cleaning.
Jan 05, 2009 | HP Pavilion zd8000 Notebook
What's the model of your laptop?
You can re-download the eData Security Software from ACER's website
http://support.acer-euro.com/drivers/index.html
Aug 26, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5570Z
Ok that is just a program that comes with the Acer laptops, it really is Useless and I dont use it on my computer, its part of the acer e management , e recovery, and etc programs that acer made. To fix this you can uninstall it under the ADD/remove programs or if you want to keep it you can then goto the acer website and under support put your model number in and download that particular software again and it might fix itself if there where some type of missing files on that particular software. Secondly if this is a vista machine it could be the software is not compatible and it causes the OS to crash which then comes with that error to the user and never goes away . Hope my answer gets you closer to a solution.
Jul 30, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3100-1405 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
