Question about Denon AVR-3801 Receiver
How to switch the Danon AVR 3801 sub woofer on with remot control
Hi, my children got at the remot control for our surround system and managed to switch the setting on the amp for the subwoofer to off. We do not have a monitor to plug in to be able to bring up the menu and switch it back on. Or at least this is what we think has happend. The whole this was working fine 12 hours ago and the TV cabinet is locked. Anyone encountered this problem befor and could advise what sequence, which buttons need to be pushed on the remote to switch the sub back on. Many thanks
Dodie
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    need to set it up with screen display on TV.
    Scholar:
  • 93 Answers
What you are going to have to do is somehow get this to a monitor, and use the remote "setup" to get to amp assignment where the subwoofer yes/no option is located.
Posted on Jan 30, 2009
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
Blown up denon avr 3801
FIXYA can not do anything for you .
Nov 15, 2017 | Denon AVR-3801 Receiver
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have a Denon Surround receiver, model AVR-1804 which manages our home surround sound system (6 speakers including a sub-woofer). When the TV (Visio HDTV) is turned off, but the receiver is still on, we...
Some kind of ground potential difference between the TV and the AVR or perhaps it's a badly shielded cable.
Considering the multitude of variations you may have connecting the TV video and audio to the receiver it's hard to pin it down, but try removing all cabling between them and that should silence the hum. Add any cable and see if it comes back. Disconnect it. Test each cable the same way. At some point a single cable might be implicated. Replace it.
Also consider routing of any analog audio cable near power cables, the TV or other sources of high voltage and magnetic fields. I have a known problem when my overhead dimmer-controlled track lighting is on. Food for thought.
Feb 19, 2011 | Denon AVR-1804 Receiver
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
Surround audio system: only 2 speakers work
Finally solved it. Push the "prologic" button several times until 4 channel appears in the display.
Sep 19, 2009 | Audio Players & Recorders
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
Danon avr 3200 subwoofer
LOOK ROUND THE BACK OF YOUR AMP AND YOU WILL SEE A SOCKET MARKED SUB PRE OUT.PLUG YOUR SUB CABLE INTO THIS AND THEN TO YOUR SUB.MAKE SURE YOU DO NOT PLUG INTO THE 6 CHANNEL IN AS YOU WILL GET NO SOUND.
HOPE THIS HELPS.
May 31, 2008 | Denon AVR-3200 Receiver
Denon AVR-3801
Is the signal set to "ANALOG" or "DIGITAL"?
Sep 29, 2007 | Denon AVR-3801 Receiver
Denon AVR-3801 Receiver Logo
125 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
