Question about Samsung SGH-t219 Cellular Phone
My speaker phone
Why is it so low? why is the volume on the phone so low anywayz i would like it to be much more higher then 5. and when my phone rings it is not loud enough and it is also on 5. and why cant i close my phone and also use the speaker phone at the same time?? can u please help me with these question's asap.
    Brigadier General:
  • 7,752 Answers
That is the volume you have...i think there is a software that can rise the actual volume on the phone but you need to take it to a mobile service center and ask about it.
Posted on Feb 02, 2008
SOURCE:
VERY LOW VOLUME
Replace the speakers.
Jun 09, 2015 | Sansui 32" TV
Speaker at low volume and can't increase
How are you connected? , if were less, try with a cable and first of all use high quality audio, no bad recorded stuff and full batteries . it should be doing it . if none of the connection modes offers a higher volume, then it's the unit.
greeting, Richard
Jan 10, 2015 | Bose Corp Bose SoundLink Mini
I cannot bring up the volume to pass 20 if i bring it up higher it shuts off
Check that the speakers are the same impedance as the amplifier is rated for and that the speaker wires or connections are not shorted. It sounds like you are trying to drive 4 ohm speakers with an amp that is rated for 8 ohms - it will work at low volumes, but will overheat and shut off if you try to drive it too hard (higher volumes)
Nov 14, 2014 | Technical Pro Audio Players & Recorders
Hello! I'm having problems during a phone call with my speaker volume being too low unless speaker phone is on. All other sounds are loud & clear. I've tried resetting & turning the phone...
Did you happen to update to iOS 5? Because since the update. Mine has been the same way. The volume is very low. and sometimes even the speaker isn't too loud either unless I'm playing music.
If you did not update to iOS 5. Then your speaker might be blocked and easily cleaned with a cotton swab, or the speaker is just old and going out.
Jul 25, 2011 | Apple iPhone 3GS Black (16 GB)
How do you set your ring tone volume higher
1.) go to settings,
2.) choose sounds & alerts,
3.) choose ring volume,
4.) then, press arrow up on your cellular keypad to have a high or loud volume; or, press arrow down to have a low/ soft volume on cellular phone.
5.) then click SAVE --- > ok.
May 11, 2011 | Cell Phones
What is the correct speaker impedance for a Sapphire XV radio? Currently only clear at low volume and then distorts at higher volume
Your factory speakers are usually 8 Ohms, and your aftermarket speakers are usually 4 Ohms. Factory speakers can only take so many watts of power. An aftermarket radio usually gives about 22 watts at a max where the factory is only about 5 to 10.
Apr 22, 2011 | Car Audio & Video
Earphone sound is extremely low - how do I adjust to a higher volume so I can hear the caller better
If the phone earphone sound is already the highest but you are hearing it low, you might want to change the speaker.
May 11, 2010 | Nokia 6030 Cellular Phone
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Speakers cutting out at higher volume
Check the power /voltage printed at back side of speaker ,test w/ volt meter /if supply not enough current to drive the amplifier.The sound are very low and humming.
Jan 02, 2008 | Audio Players & Recorders
Speaker Volume Low
open the mobile and realign the speaker back on its tracks it will work and reassemble it
Jun 01, 2006 | Samsung SCH-a670
Samsung SGH-t219 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
