Question about Dell OptiPlex GX260 PC Desktop
Dell Desktop computer Disk read error
The computer Boots past the dell loading screen but it will not recognize the operating system. I have tried to reformat it but the partition (38796mb) is not recognized.
  • LokiWarrior Dec 11, 2009
    Adding to original, same computer maker, same problem
    ran drive test harddrive passed, inserted windows xp pro install disc, it worked for me fine yesterday to redo my dads laptop but it wont seem to read on this tower, it will say its looking at the computers config but then it goes black and does not change.
  • Thomas F. Schneider May 11, 2010
    Xp?
  • 3,940 Answers
Try running Hard drive diagnostics from either the F12 menu or CNTL+ALT+D at Dell BIOS splash screen
Most likely, failed HDD
Posted on Jan 29, 2009
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
When I turn on my Laptop the Dell Inspirer E1505 it says A Disk Read error occured Press Ctrl + Alt + Dell to restart then i restarted the computer i pressed F2 and the BIOS setting came up i went to...
It's asking you for a password to access the BIOS. You or someone entered a password to access the BOIS (setup screen). The original problem you're having is "Disk Read Error". If you have the CD's that came with your laptop, look for a Resource CD or any that has "Utilities and Diagnostics" under "Contents". This is a CD that you can boot from. Insert the CD and select <F12> on power on. Select boot from CD/DVD disk. If the laptop boots then your laptop is working but your hard disk drive or OS (Operating system software) is the problem.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
Turn on my computer Inspiron 530S starts to boot up gives the dell booting page then goes to 0 Diskette error choose F1 to continue and F2 to start setup. I have tried F2 and change it to no floppy disk...
Sounds like someone may have left a non-bootable floppy disk in the drive. Check to be sure there isn't a floppy in the drive. Also, when in setup, it's the boot order that you'll want to change.
Nov 27, 2010 | Dell Inspiron 530s Desktop Computer
My Dell 531S will not boot past the BIOS (Dell logo) screen. At first I thought it was the hard drive, since it wasn't recognizing anything connected to SATA port 1. Since then I have purchased a new...
It seems like you have multiple problems:
1. DVD-ROM drive not accessing the disk
2. unable to "disable" the "floppy" drive in BIOS SETUP
3. not recognizing anything connected to SATA1 port
It's time to take your computer to a qualified technician, for professional trouble-shooting.
Is your DELL computer still under warranty? If so, exercise the warranty.
Or, maybe you should just remove the "new" disk-drive, the RAM, the DVD-drive, and then responsibly "recycle" the old computer, and purchase a brand-new system, repurposing the disk/RAM/DVD components.
Sep 01, 2010 | Dell Inspiron 531s Desktop Computer
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
My Dell 4500 will not Load Windows XP
yuppers...use F8 to go to safe mode, and then run some disk utilities
Mar 23, 2008 | Dell Dimension 4500 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
682 people viewed this question
Alun Cox
