Home | Ricoh | Aficio 1035 Grayscale Copier | Ricoh Aficio 1035 fro...
Ricoh Aficio 1035 Grayscale Copier
Problem for Ricoh Aficio 1035 Grayscale Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
By teampeterhaw on Jan 29, 2009
I purchased a Ricoh Aficio 1035 at auction from a company who went bankrupt. The unit was obviously hooked to an internal network and has a Equitrac Counter system attached. I want to use this as a basic stand alone copier/scanner. Is there a way to remove the counter and reset to a factory default, or, change the network setup to allow stand alone usage? When powered on, it flashes in the upper left corner "Cannot Connect w/ Network" "Check settings of IP address"
Then in a large error bubble on the screen it says "Set Key Counter"
I would love to be able to use this machine - any ideas?
Comments:
Jan 29, 2009
- I do not have a network...the company where I bought it from had it connected to a network, but they are out of business. I want to use this as a stand alone machine, although, if I have to, I could connect it to our computer network or a single machine. Is there a way to disconnect the Equitrac Counter (that requires a login as well) and reset it to a non-network unit?
Jan 29, 2009
- When I select interface and change the IP Address, all numbers will change to 0 except the last - the IP ends up as 000.000.000.004 - and still does not work. By the way, I appreciate your time in helping me with this.
Jan 30, 2009
- Thanks,
I will wait for the service codes. I appreciate your help
Jan 30, 2009
- 5113 = Optional Counter Type
shows options:
0:none (selected)
1: Key Card
2: Key Card
3: Pre Paid
4: Coin Lock
5: Key Card
5120 = Mode Clear Opt. Counter Removal
0: Yes (selected)
1: Stand By
2: No
Jan 30, 2009
- I disconnected the Equitrac Counter from the machine by unplugging the cable from the circuit board. After doing that, the error code SC542 shows up.
Jan 30, 2009
- I got it fixed! Thanks for all of your help!~
Clarification Request
Posted by Bubbabear64 on Jan 29, 2009
What is the IP address to the gateway on your network?
Best Solution
posted on Jan 29, 2009
Very Helpful)
Bubbabear64
Rank: Wiz  Ricoh Expert
Rating: 85%, 2094 votes
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Comments:
Jan 30, 2009
- The reason why the machine isn't working is because its looking for the key counter. To disable it press the yellow button on the copier. Press 107 buttons. Press and hold the clear button. That will get you into service mode.
I don't have the codes handy with me. I'm in the process of moving and my service manuals are at the new location. I'm waiting for a reply from another tech to find out what the code is. I should have it shortly. Once it is disabled, your machine will work.
Jan 30, 2009
- I was talking to another service tech on line and he was talking about service codes 5113 and 5120. Are those two options available in the service codes?
Was this helpful?
Yes
No
Solution #2
posted on Mar 09, 2009
Not Rated)
RicohPRO
Rank: Master
Rating: 94%, 5 votes
go into service mode using yellow key 107 and hold stop for a few second... press copy sp ... then go to number 5 = mode ... go to optional key counter and set the bit to 0....
after that is done you now want to reset the 542 which is a ricoh sc code for the fusing unit... still in copy sp mode open 7 = data log and scroll down to 807 sc/jam reset... execute....
if when you turn on your machine and it still comes up with 5xx code replace thermistors,
Ricoh Solutions Master
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1035 Grayscale
Questions and Unsolved Problems for Ricoh Aficio 1035 Grayscale
Do you recommend Ricoh Aficio 1035 Grayscale Copier?
Answer
Answer
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have... (More)
Answer
How do I take a meter reading on a Canon IR2270? Alan
Answer
IR 1600 COPIER SHOW ERROR CODE 9 HOW CAN I SOLVE THIS?
Answer
my hp k850 inkjet printer prints one paper and it not working any more until i restart it.
Answer
minolta cf3102 error 3c50 anybody know what this is
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1035 Grayscale...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
