Question about Hotpoint Ultima WF860 Front Load Washer
My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you I have just repaired my machine with a new drum assembly. On the second wash the machine has stopped and started to flash F12
    President:
  • 2,110 Answers
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Jan 29, 2009
    President:
  • 1,990 Answers
Hi.
F12 indicates 2 or 3 differant faults.
Try these first.
Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
Select a drain prog, and see if it pumps out o/k.
If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
Plz rate my solution .Thanks.
  • 15,935 Answers
F12 -No communication between circuit boards.
Possibly a duff connection on one of the board connectors. Power off, remove covers, disconnect circuit board connectors and clean with toothbrush. May help to tighten them with a pair of pliers. Clean off any corrosion or crud, refit and test. Closely inspect the entire wiring loom and circuit boards, looking particularily closely at areas where the wiring touches the machine frame. Your'e looking for any signs of wear or fraying which would allow the bare wire to contact the frame
Repair and service your own washing machine.
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Jan 06, 2013 | Maytag Performa PAV3200
Washer drum off balance
there is an alignment track that the drum rides on it uses little wheels that ride on this track to keep the drum in the right place. either the bracket holding thos wheels to the back of the drum are loose or the wheels themselves are worn. these should be checked for servicabilty or replaced the problem is not the drum itself.. please rate.
Oct 07, 2008 | LG WM1812C Front Load Washer
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi.
Try these first.
Dec 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wt741
not sure if this is repairable but wonderedif anyone else has had the same problem,my wf860 keeps flashing f-03.
Oct 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
134 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
