Question about ViewSonic VA1703wb Monitor
My computer crashed and when i turn it on, there are 2 beeps
I have a dell, and it froze. when i restarted it manually, the screen says "no signal" and there are 2 beep sequences that won't stop. please help!
  • lindsayhirth Jan 29, 2009
    how do i do this?
    Thank you so much ! It worked!!!!
    President:
  • 2,976 Answers
Here are the beep codes for Dell. Count the beeps sequences and compare them to the list.
Dell BIOS Beep Codes:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Posted on Jan 29, 2009
    President:
  • 2,110 Answers
Try to change the RAM...or check the RAM ..remove and re insert RAM...
  • Sibananda Jena
    Sibananda Jena Jan 29, 2009
    Open your CPU cabinate ..there u can find RAM slotted into motherboard...
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
Computer crashed and won't boot. restarts before it loads
Firefox is a bad virus program three thing to do
1st safe mode
if not, reboot vista disk.
If can't you need to go to bios to run cd to restart fresh program. but remember if this you loose all media.
Dec 05, 2009 | HP Pavilion DV9500Z Notebook PC
Frozen Mac Book now with blank screen and 3 beeps
Pull your ram cards and restart... see what you get. Then restart WITH them... you may just have an unseated ram card.
Nov 17, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Computer will not turn on
First off check that you havent set the Alternate display mode FN+F5 or FN+F6. or on a dell use FN+F8
If you have an external display hook it up to that and see if you get a picture.
If not then as you power up listen for any beeps (these are known as computer post codes) and look them up on the web or the dell site.
Dell also make available the "Service manuals" for most of thier stuff so go download that too as most of them have a step by step troubleshooting chart you can easily follow
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
Aug 10, 2009 | Dell Inspiron 1501 Notebook
Computer won't restart....
it appears that this is a memory problem, based on the codes that you specified.
the reference for this is:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124996
Aug 09, 2009 | Computers & Internet
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
May 14, 2009 | HP Pavilion dv5-1000us Notebook PC
Tower is beeping and monitor on/off switch is blinking
If the computer has been moved recently, I would chack the Video card in the mother board to make sure it is seated in the slot all the, Unless you have on board video.
Apr 12, 2009 | Dell Inspiron 531s Desktop Computer
Computer starts up to a blank screen
2 BEEP MEAN PARITY ERROR OR PARITY CURCIUT FAILURE, HAVE YOU INSTALLED ANYTHING NEW THAT HAS MEMORY ON IT, RAM,AUDIO,VEDIO.
ROD
Feb 12, 2009 | Dell Latitude D630 PC Notebook
Won't Turn One
Try to remove the memory card and clean it together with the memory card slot. then Turn on it again.
Dec 30, 2008 | HP Pavilion Media Center a1330n - AMD...
ViewSonic VA1703wb Monitor Logo
147 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
