Question about LG Dryers
No heat in the dryer
It takes me 2 hours to dry one load of laundry. Everything seems to work but there is no heat coming out.
  • 150 Answers
You have lost your heating element.They are fairly easy to replace.
ask me on chat live
len west
Posted on Jan 30, 2009
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Wont dry clothes, i can turn it on and wait a second then open door and heat appears to be onbut it seems to take hours and hours to dry a load
You may have a blocked vent.
Remove the connecting vent from the rear of the dryer.
Run a load of laundry.
Use timed dry at 50 minutes if possible.
If it dries correctly clean and repair the exhaust vent.
Dec 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
49 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
