Question about Singer Inspiration 4210 Mechanical Sewing Machine
Feed dogs When I start sewing it seems like the feed dogs do not move and the fabric stays in place
  • 2 more comments
  • goodgenie4u Apr 26, 2009
    Singer Stylist 513 feed does not move and advance the fabric. What can I do to determine if there is something wrong that does not require professional help?
  • Anonymous Mar 23, 2014
    will not move to make botton hole
  • Anonymous Mar 25, 2014
    it sews in reverse is there a way to fix it
    what is a feed dog
    how do you move the feed dog
    New Friend:
  • 186 Answers
It probably needs gears replaced or has a loose gear. Unfortunately you need to take it in to a repair shop. (I am assuming that you are not in button hole or have the stitch length set to zero).
good luck!
Posted on Jan 30, 2009
Yesterday, while machine quilting, I heard a clank. Now the feed dogs won't feed the fabric. The feed dogs seem to move back when I start sewing; it seems as if they stayed forward before...
Did you check to make sure the feed dogs weren't inadvertently dropped. Most sewists drop the feed dogs for free motion quilting or darning.
Oct 10, 2016 | Singer 4210 Inspiration Sewing Machine
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
Why is My fabric is not feeding through the pressure foot
the feed dogs are what move the fabric under the presser foot so the needle can sew. check your instruction manual and see where the lever is that operates the feed dogs. if the lever is up then the feed dogs will feed the fabric, if the lever is down, then the fabric will stay in place. if the lever is up and the feed dogs are not working, then it's time to have them checked.
Jun 10, 2014 | Husqvarna Huskylock Computerized 905
Feed Dogs wont move fabric on a Viking Prisma 990
the feed dogs need to be checked, they may need some type of adjustment.
May 03, 2013 | Sewing Machines
I have a JukiLU562 and fabric won't move starting to sew
the feed dogs are what move the fabric thru the machine to sew it
if the feed dogs are not working, then they need to be checked
to see if they have some loose or broken or need to be retimed
Jun 05, 2012 | Juki Sewing Machines
Sewing Machine fault
Perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjv-KjEyNLXAhXDwFQKHZJtD4sQFggmMAA&url=https%3A%2F%2Ffiles.tv-sewingcenter.com%2F2015%2F04%2Felna-sew-fun-instruction-manual.pdf&usg=AOvVaw08q0vhbb6YSyyVVTwMCUKH
ELNA Sew Fun Instruction Manual
The feed dogs on your machine do not drop. Instead, the machine has a darning plate that covers the feed dogs (see the accessories listed in the manual). If the darning plate is installed properly, it should prevent the feed dogs from contacting the fabric.
Make sure the stitch length dial is set @ 2 or higher. This will insure the fabric will move as the machine stitches.
Nov 22, 2017 | Elna 2007 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Singer Inspiration 4210 Mechanical Sewing Machine Logo
340 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
