Error code 105
I have a IW812 F&P Washing Machine that is 2 years old.
Its giving the error message above.
When the power in connected, the error message is displayed first.
Please help to rectify and to get back to washing.
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
Dec 26, 2017 | LG WM Washing Machines
My Iw812 jumps across the floor and displays our of balance
I have the same machine in the laundry,(IW812)
This is normal for large bulky items to get stuck to one side of the bowl when spinning dry.
Feb 03, 2013 | Fisher and Paykel (IWL12)
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Nov 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Has error message 66 and 38 model IW812
Hi - Code 38 is pressure related: remove the rear top corner (2) screws, locate the clear tube with a clamp on, blow into it away from the the controls, insert & try again.
Under no conditions do you blow pressure into the transducer or the electronics end - it will damage the unit.
The problem with the washer is that the motor controller has sensed the lack of water in the machine as so to speak, hence the error.
Code 66 - is also the same issue as code 38. Worst case scenario you need to replace the motor controller module.
Jun 17, 2011 | Fisher and Paykel Washing Machines
I have a Kenmore HE 2 plus washing machine. I washed and old blanket in it and I think it totally fell apart into small pieces and clogged up the machine. I have an F21 message and the machine is locked....
Sorry to read about your problem, I hope this helps you out.
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
n After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
prese stop twice to clear display
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step
7. Unplug washer or disconnect power.
8. Replace the pump.
Jan 02, 2011 | Washing Machines
Hotpoint Ultima automatic washing machine, half way through wash cycle the display flashes F 03. The machine is less than 2 years old.
Error code F03 indicates wash thermistor open/short circuit.
Check all connections on thermistor and associated leads.
Hope thisn helps.
Nov 27, 2009 | Washing Machines
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a fisher and paykel washing machine IW812 and it has error code 49....Can you please advise what the problem is and how to fix it?
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
Oct 25, 2008 | Fisher and Paykel Washing Machines
E90 on Front load washing machine
E 90 is an error code regarding the main pc board connection.
the solution is to secure all connection to and from the main board.
tighten the sockets and make sure they are not loose that could create a problem while vibrating and shaking.
tnx 4 using fixya,
drcool
Sep 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
