Linksys 5-port switch model ezxs55w
I have 2 computers-I hook either one to router and they work-I hook both to the switch and one works but the other one won't-both computers run windows XP home.
    Problem Solver:
  • 13 Answers
Is this the DSL router that comes from the ISP or is this one that you purchased for this purpose?
The problem would seem to be that you are probably only getting one IP address. If this router is from the ISP then you are probably only getting one IP address. If this the case you will need to either request another router that has the ability to act as a DHCP server. If this is not an option, then my solution would be to get another router/switch that will provide IP addressing. This would solve your problem.
However, with not knowing whether you are getting ip addresses on both computers this is just my best guess based on the information provided.
Hope this helps.
Posted on Jan 29, 2009
EZXS55W not configuing with an ip
Should be 192.168.1.1. Start > Run >type ipconfig /all. Default Gateway id the IP. You can also reset the router.
Jul 29, 2012 | Linksys : EZXS55W 5 Port Desktop Switch...
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I need to know how to open a port on a linksys ezxs55w switch.
I don't believe you can open a port on this switch. You need an actual router to be able to open ports. The switch itself is not routing anything, just acting as a switch. You will probably need to connect a router to be able to open/forward ports.
While the "no configuration required" feature seems nice when purchasing this switch, it unfortunately does not allow you to configure it when you do want to.
Dec 19, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Nov 18, 2009 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
Can't get two computes to run internet at the same time
If you login to your router and make sure DCHP is enabled, and then go to Services (services.msc) on your computers and make sure that the DCHP Client is running, it'll automatically assign IP addresses for your computers and they'll both connect okay.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Linksys EtherFast 10/100 5-Port Auto...
EZXS55W 5-Port Workgroup Switch
This is a wired network switch your inquiring about. Is this plugged into a wireless router?
If so what brand is the router.
Jun 10, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Computers & Internet Logo
677 people viewed this question
David Payne
David Payne
