Question about HP LaserJet 4250n Printer
Fading down the middle
The middle of the page comes out blank all the way from top to bottome - replaced cartridge, drum and roller
  • 2,120 Answers
Lower then remove rear door.
Lift the two blue tabs , remove the fuser and inspect the top roller
Posted on Jan 29, 2009
HP laserjet p2055dn blank page print
A little more information would help with diagnosis but here goes.
First up - check you removed ALL the seal strip from inside the cartridge when you installed. it.
second - check the toner cartridge is pushed ALL the way into the cartridge bay and is firmly located.
If all good then:
Empty toner cartridge - has been working but faded and now nothing. - replace the cartridge.
New cartridge - return to supplier
- could be primary charge roller - replace cartridge
- could be drum problem - open drum shutter on cartridge and have a look at the drum. If it is absolutely clean try it again. If it is totally covered with writing or black, you have a charge transfer problem inside the machine and the latent image is not being transferred to paper.
If you cartridge was a refill - take it back to refiller for testing.
Feb 13, 2018 | HP Office Equipment & Supplies
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Dell 1710 printer. When printing just tthe top 2
Have you tried replacing the drum? That is the part that the toner cartridge actually sits in.
Jan 28, 2010 | Dell 1710n Laser Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
The pages on the right side come out faded or not printed at all. The printer is only a couple of years old, no more than 5-10k total pages printed. On second set of cartridges.
If its happening with single shade color
1) Take the Cartridge out of the Printer and shake it
2) Clean the cartridge drum with the Tissue Don't Rub slightly clean it
3) Take the Cartridge out and shake it
If page comes faded on every print Black or Color then there must be a Roller issue which is not clean
1) It could be the Roller side is not clean -
Need service for the Printer
Jan 03, 2010 | Konica Minolta Magicolor 2450 Printer
Dirty copies
When you replaced the drum did you printed like 15 pages? Did you noticed any change in the ouput of the line did it fade?, if you are 100% sure that the cartridge is ok., then check the fuser and/or the transfer roller. Make sure that the printer is clean inside.
Dec 21, 2007 | HP LaserJet 4350TN Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet 4250n Printer Logo
Ben Johnson
