Question about Fuji FinePix J12 Digital Camera
How to disconnect my usb cable from the fuji camera
I connected my fuji camera to the laptop to transfer some pix but the terminal conneted to the camera holds tightly, coould not remove it. please help me out
  • 60 Answers
Put a drop of WD-40 around the plug/socket and let it soak in.
With a hair dryer atits lowest setting (warm only) blow onto the socket and wiggle it out.
For future use a minute film of silicon grease will solve your problem.
Posted on Mar 07, 2009
Can i charge my camera with the usb
No, charging the battery via USB port is not possible with your Fuji Finepix Z20fd Digital Camera. The USB port can be used for just 2 purposes: (1) connect to USB-compatible printer (to directly print pix), and (2) connect to a PC with a USB port (to upload pix). The only way to charge the camera's batttery
looks like the separate "supplied battery charger."
Check out page iv. of the onine version of your camera"s Users Manual.
Jun 09, 2011 | Fuji Finepix Z20fd Digital Camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Mar 10, 2011 | Nikon Coolpix L11 Digital Camera
My fugi j40 wil not download to my laptop, i have installed the cd software and when it comes to prompt me to download it says if it doesn't download in one minute refer to help all that has been done,...
So there is a connection problem as in with the camera off connect the cable between the computer and camera and in most cases turn the camera on, however I've found on another Fuji camera that to transfer pictures from the camera to the computer you press the preview button. It may look like an arrow pointing right. A suggestion though would be to purchase a card reader (fairly inexpensive) and plug this into the USB port and the camera memory card inserts into it. The computer then look at it as an external Hard Drive. Load the files to a folder on your computer and then open the folder in your image software. When you are finished with the transfer do a safe disconnect or eject make sure the transfer is completed and the device is shut down before disconnecting the USB cable or removing the memory card (it sure doesn't like you if you don't) Also make sure you format the memory card after each down load it makes the camera and memory card compatible once again.
Jan 16, 2011 | Fuji Cameras
My Dell 942 All-in-One does not recognize the FinePix E550 card. I'm not sure what I need to download to be able to transfer my pix to printer. This camera was given to me recently and I don't have the usb...
You need to install the camera software on the computer then print from there but you will need a USB cable to connect to the printer,just check your camera does not require a special Fuji cable. Or possibly a card reader direct to the printer will work but I am not sure on that one, see printer manufactures for information on this. Good luck
Dec 29, 2010 | Fuji FinePix E550 Digital Camera
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Unable to transfer photos from memeory card with usb cord
uninstall fuji software from laptop. plug in data cable, pc will ask u for drivers then load it. if not then pause antivirus for while then use data cable
Jun 18, 2009 | Fuji FinePix Z10fd Digital Camera
Photos from camera to PC
u dont need any software to download the photos to PC
Fast Option : take out the XD memory card from the slot and slip it in the mem card reader fitted in laptop and external alos available cheap
Normal Option : just connect ur camera thru the usb cable provided with the camera and connect the usb to pc and it will come up as removable storage drive in my computer u can then browse and copy the pics to PC , but if it doesnt work then check the settings in menu of camera ur camera have 2 modes of connectivity to pc one is webcam that is PC mode and choose the second mode that is for file transfer , u have to put ur camera jog dial to play mode to detect ur camera on pc
then u can also use Fuji Fine Pix Viewer further to copy and enhance ur photos if u like
pls rate me FIXYA for this help if u like
Mar 16, 2009 | Fuji FinePix S5700 Digital Camera
CD software and USB Cable
If you have a Card reader where you can put the memory card of your camera on it that will do the trick in transferring pictures from the camera to the computer and vice versa, but the best way that you can do is to buy a USB cable for your camera there are generic type of USB cable that are use for camera and its pretty cheap and for the software you can download it from Fuji's web site..
Hope that helps..........
Aug 11, 2008 | Fuji FinePix A345 Digital Camera
Fuji Fine Pix Z1 - 'Card not initialised'
format the card through the set-up menu.
Mar 28, 2008 | Fuji FinePix Z1 Digital Camera
Fuji Pix A330 File Transfer Mode
Keep the batteries out and try to examine the port where the cable plugs into. There are 4 metal leads on one side of the port tab and 3 on the other. They may be bent or crossed by debris
Feb 03, 2008 | Fuji FinePix A330 Digital Camera
Fuji FinePix J12 Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
