Photo copier i have different size boarders when printing photo's
  • Tim Babcock
    Tim Babcock May 11, 2010
    Which borders are different sizes?
  • 92 Answers
Clean the roller right under the drum black rubber with water and soap dry very well shouild be ok that part is called the timing roller
Posted on Aug 29, 2009
Print Column Headings & Grid lines on a Spreadsheet
Dear Leoandpollyk
select the range on spreadsheet of which the grids to be printed.right click select format.on this window click boarder here select bothe coloumn and row lone then click ok. this will shows the range slected in darker grid also can prints.
thanks.
Mar 31, 2015 | Canon PIXMA MP230 Multifunction color...
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
How do i go about printing different size of photos? they are all different sizes.
There are two basic ways to change the print size of your photos/documents.
1. You can go to file/print or you can press cntrl + p on your keyboard. the print menu will come up. go to properties/features. when it opens, look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. other procedure is to right click on the photo/image and select print. a print wizard will pop up. it will ask you to chose size of images.
Good luck,
Ryan
Jun 11, 2011 | HP Deskjet D4160 InkJet Photo Printer
The boarder of the page at the bottom doesn't appear although I print on A4 size. How can I solve this problem. Thanks my e-mail is eaziz900@yahoo.com
Select a different size paper or change your margins. If your paper isn't markd size A4, use whatever it is marked as.
Aug 06, 2009 | HP LaserJet 1018 Printer
Boarders and titles
A name and date is very simple you can go to the control panel- Tap twice on the top left of the welcome screen and enter your four digit code default is 9999 - Click on the ikon at the top of the screen relervant to text - You can then type a Company name, Date or Tel No: - select font colour size and position - I would suggest white - You then click on
the add text button and it will be on all prints until you change it or switch it off - We put our Name, Tel No and a number to designate which printer it is as we have five of them and if we have a problem I know which one needs fixing.As to adding a company logo and date
in the borders section you would first need to create a border design
in photoshop or other editing program import that into the border creating software that came with the machine then save this to a borders folder on you computer - Then if you have a compact flash card in the expansion slot on the inside of the ribbon carrier door remove it
and add your new border to the borders folder on the card and replace it in the machine. If you havn't then copy the border directory from the CD
supplied with the machine to you hardrive add you new border to this folder then copy it to your new compact flash card - Place this in the expansion slot in the side of the machine as above.When you now
switch the machine on and enter the print mode select the border ikon and you should see all your borders - Select the one you require and print - If you print different sizes you will need to create a border for each size - You can also go to the control panel and set the machine to add a border every time it prints but I have never needed to do that but
it will but in the owners manual and won't be to difficult I assume.
Jun 11, 2009 | Sony SnapLab UP-CR10L Digital Photo...
Printable area
hey did u have page set up .in file menu go through that ....
or u can go to format(icon)at the top in M.S office . go in boarder
& shading set frm there ....
Feb 19, 2008 | HP PSC 750 All-In-One InkJet Printer
4 x 6 photo printing
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=184&modelid=11864#SupportDetailAct
Jan 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Font size
You can change the dfont size from the menu, but that setting afects the entire page of print. You different size fonts are controled from the codes sent to the printer from the software. Recreate the document, or create a document with a sample of that small print and see if the printer prints it.
Dec 04, 2007 | OKI MicroLine 420 Matrix Printer
Sizing the photo
Unfortunately, the P400 seems to have its own set of sizes. The printer will give a print close to the size selected. (This is really noticeable with the perferated psper.) The situation is no different with the P440.
Sep 03, 2006 | Olympus P 400 Thermal Printer
20 people viewed this question
jasbo
jasbo
