I have two pc one on wireless the other on cable
Hello I was hoping to network my two pcs together but I have a problem the one on wireless will let me look at the files on the one that is cable but the one on cable wont let me look at the wireless one said this
(server is not accessible. You might not have permission to use this network resource. Contact the administrator of the server to find out if you have access permissions.
then it says The network path we not found)
But im the administrator I have check all the network setting they are fine has the same workgroup and everything i dont understand why it wont let me because if I plug a cable in i can access it but thats a pain as have to keep moving router closer
is it because ones on wireless and ones on cable
  • 257 Answers
Hi, First let me say it could be several things so you need to be patient with the answers, since we don't have all of your info. Sounds like the file sharing is not enabled on the wireless one but if you want to share between them check them both. A word of caution before proceeding is file sharing between computers connected to a router may allow the files to be viewed by others. OK assuming you have xp or vista, in the control panel under network settings you will have file sharing on the menu in vista and xp will have lan, local or wireless settings pick the one you are using and right click properties, and make sure that the box is checked for file and printer sharing for microsoft networks. You didn't say what type of wireless you are using but the same settings apply to your router, you have to enable file sharing over wireless make sure you encrypt it or you will be at risk. Good Luck!
Posted on Jan 29, 2009
    Problem Solver:
  • 13 Answers
What version of windows are you running? Also, are you saying that if they are both on a wired connection that you can access each?
If that is the case then I would suggest to you that the problem is in the one with the wireless connection specifically in the wireless software that you are using. In most wireless configurations it will let you select whether the network you are connected to is Home, Work, or Public. If the connection is selected as Public it will deny sharing. You can either delete the auto connection for the wireless connection and then readd it using a friendlier configuration or you can try to modify the connection through the use of the software. I would recommend deleting the account and using the wizard first.
Hope this helps.
How do I connect tablet to my computer?
Unless your tablet and PC have bluetooth and can pair up together, this can sometimes be an issue. Folks think that since their tablet is wireless and connects to their home network, they should be able to access it from other PCs/devices on the network. Unfortunately, although tablets are computing devices, they are not computers in the same definition as PCs are. They do not have domains, workgroups, or homegroups inherit to their OS. Thus, PCs on the network don't see them. If you have a USB cable to connect the tablet to the PC, then you may see the device as an added one since the PC's OS can assign the device a drive letter. Most folks want this connectivity to transfer photos and videos from one device to another. If you cannot physically connect the two units via cable, you might try to find an app that will allow you to get the devices talking to each other. There are FTP apps that will get the two together for file transfers and the like.
Jan 12, 2016 | Tablets & eReaders
Problem with hp pavilion g6 wireless
I will be happy to help with your wireless issue. However, that is difficult as you didn't leave a lot of information to work with. I have included a few links below depending on your operating system.
HP Notebook PCs Troubleshoot Lost Internet Connection on Wireless Network...
HP and Compaq Desktop PCs Troubleshooting Your Wireless Network Windows...
HP PCs Troubleshooting your wireless network and Internet connection...
HP PCs Troubleshooting Wireless Network and Internet Windows 8
Here are a few additional wireless troubleshooting steps that you can try:
Power cycle the network:
1. Shut down your notebook.
2. Unplug the power to your router.
3. Unplug the power to your modem.
4. Wait at least 45 seconds.
5. Plug in the modem, and wait for it to come back online.
6. Plug in the router, and wait for it to come back online.
7. Turn on your notebook, and test your connection.
Reset the TCP/IP settings:
1. Go to your start screen/menu and type CMD.
2. Right click on the command prompt icon and chose Run as administrator.
3. In the window that opens type "netsh int ip reset resetlog.txt" without quotes, and press enter.
4. Restart your PC and test.
Reset the winsock catalogue:
3. In the window that opens type "netsh winsock reset" without quotes, and press enter.
Change power management option for your wireless adapter:
1. Open Device Manager.
2. Expand the Network adapters.
3. Right click on the Ethernet/Wireless Adapter and click Properties.
4. Click the Power Management tab.
5. Remove the check mark beside Allow the computer to turn off this device to save power.
6. Click OK.
7. Test.
Forget the Network and reconnect (Windows 8):
1. Press Windows Key + C
2. Click Settings.
3. Click Change PC settings.
4. Click Network on the left.
5. Click Manage known networks.
6. Click the network name.
7. Click Forget.
8: Reconnect
Thank you,
BHK6
I work on behalf of HP
Apr 27, 2014 | HP Pavilion dv6000z Notebook
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
I can not get by daughters compute to hook up to my netgear wireless router. My other computers had no problem in getting connected. We have tried everything and can not get it to take the router
Hello
Have you tried going to control panel,network and sharing center.
Once there, make sure all pcs are on the same network,either homgroup or public.
Your daughters needs to be on the same network as the others.Also be sure the firewall is not blocking any connections.
You may also want to reboot the router do this by...
1 shut down all pcs
2 Unplug all cables from router including power.
3 Let router set for a min then plug all cables back in and power up
4 Once you get stedy lights on router restart pcs.
Jan 12, 2011 | NetGear Computers & Internet
Hello, I got a Dell Inspiron mini 10 for christmas. and i can be on my home wireless network. then it will suddenly drop signal and i wont be on the internet any more. what's wrong with it?
hi Power off your router and wait about 45 seconds then plug in the power to the router again, restart your dell mini and see if the connect gets more stable. do you have any other wireless pc's in the house? if so do they work fine? if you dont have any other wireless pc's try to get a friend to come over with a laptop and see how their connection is to your network... that will definitely isolate if you have a router issue or a PC issue. keep in mind if you have other pcs in the house and they are hardwired into the router, they will not exhibit the connection loss that wireless pcs connected to the router will experience.
hope this helps!
Dec 27, 2009 | Dell Inspiron Mini 10 Notebook
Network question
As long as both computers are connected to the same network then yes, you can use the LAN to play games
Jul 15, 2009 | Dell Computers & Internet
D-Link DIR-625 - wireless problem
with your situation you can see the wireless network but cannot connect you have to change your DNS.
*that will depend on your operating system.
Jun 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
Networking 2 computers
Yes you can make a simple Network between 2 PCs ....but ....you need what is called a "crossover ethernet cable" or "xover". A standard RJ45 ethernet cable WILL NOT work.
You also need to make sure both Pcs are in the same Workgroup and have unique computer names.... as is standard in Networking.
Dec 31, 2008 | HP Pavillion ZV6000 Notebook
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
