Question about Acer Aspire 5100 Notebook
Acer aspire one how to reset
Icons in lower left corner of screen which has power,connection,volume, does show up when i turne on note book.
  • Mike Gagnon
    Mike Gagnon May 11, 2010
    You did not say what O/S you are using. Need to know to give you correct Directions on replacing Icons.
Samsung galaxy s5 will not hard reset
Hi Anthony
  1. From your home screen press the Apps icon in the lower right corner.
  2. Find and press the Settings icon.
  3. Scroll down to the users and backup section and press the Backup and reset icon.
  4. At the bottom of the next screen press where it says Factory data reset.
  5. Hit the Reset device to complete the process.
Second way of resetting your Galaxy S5.
  1. Press and hold the power button to turn the device of.
  2. If your device does not respond, remove the battery and put it back after a few seconds. ( Don't turn it back on )
  3. With your device of press and hold the volume up and the home button, then without releasing the two other buttons press and hold the power button as well.
  4. Hold them depressed until your phone boots with the words Recovery mode in the upper left corner .
  5. To navigate the recovery mode screen use the volume up and down to go up and down. Use the power button to select an option.
  6. Press the volume down button three times until the Wipe data/factory reset option is selected.
  7. Press the power button to select this option.
Mar 04, 2016 | Samsung Cell Phones
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
Turn on WIFI on Aspire 3620
Locate the Wireless LAN switch located on the front of your Acer Notebook.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Connect."
Power on the Acer Aspire laptop.
Right-click the wireless Internet icon in the lower right corner of the desktop.
Select "Enable" from the pull-down menu.
Right-click the wireless icon again.
Select to view all available wireless networks in the area.
Momentarily a window appears with all of the available Wi-Fi networks.
Select the Wi-Fi network you want to connect to, then type in the password (if required).
Click "Connect," and your Acer Aspire computer connects to the Internet.
hope this helps
Oct 11, 2012 | Acer Aspire 3620 5560 TravelMate 2400 2420...
The volume of my aspire note book is very low what can i do to fix it
Well, either your windows volume (normal volume control in the bottom right corner of your screen) or whatever program you're running to produce the sound (iTunes, Media Player, etc.) is probably turned down low. Check that first, otherwise, your speakers are probably dying, and need to be replaced (quite the fix).
I hope this helps!
May 04, 2011 | Acer Aspire 5610-4648 Notebook
I have a Acer Aspire laptop 4810T. It turns on perfectly fine and everything shows up on the screen but it's so hard to see. The the screen almost appears to be black.
Press Fn key (at bottom left of keyboard) and while holding it down, press F6 key (at top center of keyboard). This should turn on the display screen backlight which had been turned of to save power.
Mar 17, 2011 | Acer Aspire 4520-5950 Laptop
I have problem with my acer aspire one note book, even after shut down i see light on bottom left corner,on screen and, if i remove battery then it goes, and again comes when i connect battery, thanks,...
make sure you are not just selecting sleep option instead of shut down, some comps have the sleep option set where the shut down one is .
hope that helps
Jan 09, 2011 | Acer Aspire One PC Notebook
How to turn on the wireless key for acer aspire one
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Locate the wireless router for your network and verify that it is plugged in and powered on. When turned on, you will see a series of lights illuminated on the front or top of the device.
· 2 Power on your laptop computer, if it is not already turned on.
· 3 Press the "Fn" and "F2" keys simultaneously to turn on the wireless connectivity option for your Acer Aspire One. You may need to press these keys several times until the light above the wireless symbol glows orange.
· 4 Click the "Wireless Network Icon" in the system tray at the lower right corner of the screen. This icon looks like a computer with semi-circles next to it.
· 5 Select the SSID of the wireless network that you wish to connect to, then click the "Connect" button.
· 6 Type the security key for the wireless network when prompted, then click "Connect."
Oct 19, 2010 | Acer Aspire One PC Notebook
How do I control the volume on my acer 5532?
Look for the speaker Icon at the bottom RH corner of the lower tool bar. If it has a red slash sign on it click with the left mouse key, it should go off. ThenClick and hold it again to display the bar graph of volume level. Adjust accordingly.
Jul 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
My husband accidently removed my audio in my acer aspire computer. how do i get it back?
I am not sure what your husband exactly removed, but if he deleted the sound driver, you can get it back from the acer site:
just select notebook, then aspire, then the model 3610
look for the audio driver
Jan 30, 2010 | Acer Aspire 3610 Notebook
Unable to change volume control on the keyboard
can you access the "speaker" icon on lower right corner of the screen ?
If not can you access sound control from control panel ?
May 23, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5100 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
