Question about Lexmark X342n All-In-One Laser Printer
CANCELLING AN INCOMING FAX JOB
LEXMARK 342 - HOW TO CANCEL A 100 PAGE INCOMING FAX.
  • 382 Answers
SHould be able to power down unit and remove power cord for few minutes. That should erase the Stored memory that it has been set into.
Posted on Jan 29, 2009
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
http://www.edvdrucker.de/Downloads/Handbuch/Lexmark/Lexmark-X254-User-Guide.pdf
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
Panafax DX-800... shows memory full 100%. Scanner does not work. Pls advise how to cancel all memory as I do not need the incoming documents. Thanks.
Unplug the machine from the rear
Hold down the ENERGY SAVER key while plugging back in
Scroll down to ALL JOB CLEAR
Press SET
wait for the machine to INITIALIZE
Feb 08, 2010 | Panasonic Panafax DX-800 Plain Paper Laser...
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
CANCELLING INCOMING FAXES
Unplug the phone line and unplug the fax machine. Then clear the memory if it starts printing out again.
Mar 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cancelling Incoming Faxes in Memory
see manual (can be download from homepage www.brother.com). If you are a victim of spam faxes you better buy a new mfc with a pc-fax-incoming-transmission function (e.g. mfc 440cn etc.) This will give you the opportunity to have a look at the faxes on the screen first and then to decide which one should be printed.
Jan 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Lexmark X342n All-In-One Laser Printer Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
