Question about Dell Dimension 2350 PC Desktop
2350 added ram now computor will not boot
Added 1g of ram 2100 266hz now it wont boot even with the 256 memory
  • 1 more comment
  • shep_ny Jan 29, 2009
    I bled off everything, what I ended up doing was removing the ram and removing the battery and bleeding off everything for 1 minute, then reinstalled everything and booted up, on boot-up hit the F-1 key and up and running. thank you everyone
  • Thomas F. Schneider May 11, 2010
    Beep? One more?
  • Alex M
    Alex M May 11, 2010
    Can you get into the bios by tapping the F2 key as it is starting up?
    if you can,then look for a choice such as "Load Bios defaults" or some such(each bios is different) then restart and see what happens.
    Then repost back here if it still wont work.
    report how far the computer will go before quitting.
  • 3,940 Answers
A couple things.
#1 Before you started inserting and removing RAM, did you have the power disconnected? Did you blead the stored power in the motherboard by holding the power button after unplugging? Not having power removed from the system can damage the RAM and possibly the slot.
#2 When inserting RAM, it is important to have the locking levers spread, align the keyways in the Memory slots, then when inserting the module, press down FIRMLY with both thumbs till the locking levers snap up and in to locked position without touching the levers. (If you pull the levers up, the RAM doesn't seat in the slot)
#3 when you power on, on the back of the tower are 4 LEDs marked ABCD they should flash on then off in difference sequences during post, then end with all for solid green. If some are amber then there is a HW problem ans you need to post the LED pattern (AAGG for example is a memory problem)
Most likely seating the RAM properly will solve the issue.
Posted on Jan 29, 2009
  • IQUIT Jan 30, 2009
    If it isn't too much trouble, could you rate the assistance you received?
    Thank you. =)
Slow loading,game cutting off
Try adding more RAM
Adding more ram will boot applications / games quicker
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask or get working pairs in a ram upgrade some ram modules wont work together even if they are of the same brand and type ie: DDR ,DDR 3
Checking Amount of RAM
Click on "My Computer" and select "Properties" using right-click in the Explorer window.
This will open "Systems Properties."
Click on the "General" tab.
Here you can view the physical memory installed on your computer.
The amount indicated is the total RAM installed on your computer.
RAM is usually 32 MB, 64 MB or 128 MB in older PC versions.
Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
Check the usage.
To know the currently used RAM (based on programs you are running), open the taskbar or press "Ctrl + Alt + Del" to open a pop-up window. Click on "Task Manager."
Click the "Performance" tab.
You can view the amount of memory currently used by each program running on your PC.
Mar 18, 2014 | Computers & Internet
New ram not working
Sounds like you bought the wrong kind of memory. It should be DDR PC2100 and it must be ECC (Not None Ecc).
Take a look at this site.
http://www.4allmemory.com/memory/compaq-hp-workstation-xw6000/
May 11, 2012 | Compaq HP Workstation xw6000 PC Desktop
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Added ram, now wont boot long beep
try removing the ram and try again
Jan 04, 2009 | AOpen AX4B-533 Motherboard
Adding memory
Try re-seating the RAM. If that doesn't work ensure that your laptop supports the ram you bought. If the RAM you have is PC2700 and your computer only supports up to PC2500 (for example) it wont work.
Aug 19, 2008 | Sony VAIO FRV25 Notebook
Ram Sharing
there is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
Aug 08, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Ram not showing up
These are the spec of memory you can use .
If it does work by itself it might be defective of not compatible with yous system.
Thank you
Memory Installed 512 MB (2 x 256) Maximum allowed 4.0 GB* (4 X 1 GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Jun 04, 2008 | HP Pavilion a815n (PS512AA) PC Desktop
Adding RAM
before you buy this memory stick (ram) you should have check the specifications of this ram memory, they should be the same specs, the cast latency might be different and with different brand. how about if you remove all this ram memory and use only this KVR133X64C3/256, if this works then do not install the other 2
Dec 06, 2007 | IBM NetVista PC Desktop
Dell Dimension 2350 PC Desktop Logo
Alun Cox
